Re: [mpich-discuss] MPICH v3.2 and SLRUM
You can also use the environment variable HYDRA_LAUNCHER_EXTRA_ARGS to tell mpiexec to add more arguments to srun while launching the applications. -- Pavan
On Dec 1, 2015, at 12:39 PM, Guo, Yanfei <[email protected]> wrote:
Hi Andreas,
I am guessing that you are using "--cpu-freq" option of srun. One way to go is manually setting the SLRUM_CPU_FREQ_REQ environment variable. Srun suppose to pick that up.
Yanfei Guo Postdoctoral Appointee MCS Division, ANL
On 12/1/15, 11:22 AM, "Andreas Gocht" <[email protected]> wrote:
Hey
yeah mpiexec is working quite well. I'd just liked to use slurm, as our implantation allows to set the cpu frequency on a node. Is there a way to pass flags to srun using mpiexec?
Thanks four your help.
Kind Regards
Andreas
Am 01.12.2015 um 17:41 schrieb Balaji, Pavan:
Looks like SLURM is telling MPICH that two processes are on the same node, even though they are on different nodes. It looks like a bug in the SLURM PMI implementation. Did you try simply using mpiexec instead? You'll need to remove the --with-pmi, --with-pm, and LDFLAGS/LIBS options and rebuild mpich for that. Note that mpiexec will internally use srun on slurm environments.
-- Pavan
On Dec 1, 2015, at 5:56 AM, Andreas Gocht <[email protected]> wrote:
Hey
I tried to build an use mpich with slurm, sbatch and srun. Unfortunate it looks like MPI_Init doesn't work with srun.
I got the following error:
Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(474).................: MPID_Init(190)........................: channel initialization failed MPIDI_CH3_Init(89)....................: MPID_nem_init(272)....................: MPIDI_CH3I_Seg_commit(366)............: MPIU_SHMW_Hnd_deserialize(324)........: MPIU_SHMW_Seg_open(865)...............: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory In: PMI_Abort(4239887, Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(474).................: MPID_Init(190)........................: channel initialization failed MPIDI_CH3_Init(89)....................: MPID_nem_init(272)....................: MPIDI_CH3I_Seg_commit(366)............: MPIU_SHMW_Hnd_deserialize(324)........: MPIU_SHMW_Seg_open(865)...............: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory)
I configured MPICH with "./configure --prefix=<some/prefix> --with-pmi=slurm --with-pm=none --with-slurm=<path/to/slurm>" and compiled my application with the "-L<path_to_slurm_lib> -lpmi" command.
(as described in
https://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Note_that_....
and
https://computing.llnl.gov/linux/slurm/mpi_guide.html#mpich2
I am running with 10 nodes and one task per node. Is there something I am missing during the configuration of MPICH?
Best,
Andreas
-- M.Sc. Andreas Gocht
Technische Universität Dresden Center for Information Services and High Performance Computing (ZIH) D-01062 Dresden Germany
Contact: Willersbau, Room A 104 Phone: (+49) 351 463-36415 Fax: (+49) 351 463-3773 e-mail: [email protected]
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
