Re: [mpich-discuss] How to make a non-MPI process to become a MPI process of MPI_COMM_WORLD?
Hello, Balaji. The example from OpenMPI is attached. Thank you very much. At 2015-01-25 03:16:35, "Balaji, Pavan" <[email protected]> wrote:
You are missing some files needed to run your program. Also, can you please attach files instead of copy-pasting code into the email?
-- Pavan
On Jan 24, 2015, at 7:57 AM, haozi <[email protected]> wrote:
Hi. The following server/client example is selected from OpenMPI. I compile and run the example by using OpenMPI, everything is OK. BUT, I compile and run it by mpich(3.1.3), which is BLOCKED as my example!
This is a bug?
#include <stdio.h> #include <stdlib.h> #include <string.h> #include <errno.h> #include <unistd.h> #include <mpi.h>
LOGIC:
- the 'server' opens a port and write the info to a file - the 'clients' open the file and connect to the port - after each accept, the server and client do a merge to convert the intercomm to an intracomm
DETAIL STEPS:
- server open port - server does accept - client #1 does connect - server and client #1 do merge - server does accept - client #2 does connect - server, client #1 and client #2 do merge - server does accept - client #3 does connect - server, client #1, client #2 and client #3 do merge
#define TAG 0
#define CHK(code) do \ { \ int retval = code ; \ if (retval != MPI_SUCCESS) \ { \ fprintf(stderr, "Error: " #code "\n") ; \ exit(1) ; \ } \ } while(0)
int main(int argc, char *argv[]) { char hostname[255] ; char buff[255] ;
int role ; int num_clients ; int size, rank ;
FILE *fp ; char server_port_name[MPI_MAX_PORT_NAME] ;
MPI_Comm intercomm, intracomm ; MPI_Status status ; int msg_count ; int i ;
/* sanity check the args */ if(argc != 3) { fprintf(stderr, "usage %s <num clients> <1:server | 0:client>\n", argv[0]) ; exit(1) ; }
num_clients = atoi(argv[1]) ; role = atoi(argv[2]) ;
if (num_clients <= 0 || (role != 0 && role != 1)) { fprintf(stderr, "usage %s <num clients> <1:server | 0:client>\n", argv[0]) ; exit(1) ; }
/* initialize MPI */ CHK(MPI_Init(&argc, &argv)) ;
/* get the node name */ { int retval = gethostname(hostname, 255) ; if(retval == -1) { fprintf(stderr, "gethostname failed: %s\n", strerror(errno)) ; exit(1) ; } }
/* server */ if(role == 1) { printf("SERVER: on node '%s'\n", hostname) ;
/* open port to establish connections */ CHK(MPI_Open_port(MPI_INFO_NULL, server_port_name)) ;
printf("SERVER: opened port=%s\n", server_port_name) ;
/* store the port name */ fp = fopen("server_port_name.txt", "w") ; if(fp == NULL) { fprintf(stderr, "fopen failed: %s\n", strerror(errno)) ; exit(1) ; } fprintf(fp, "%s", server_port_name) ; fclose(fp) ;
/* the server accepts connections from all the clients */ for(i = 0 ; i < num_clients ; i++ ) { /* accept connections at this port */ CHK(MPI_Comm_accept(server_port_name, MPI_INFO_NULL, 0, i == 0 ? MPI_COMM_WORLD : intracomm, &intercomm)) ;
printf("SERVER: accepted connection from client %d\n", i+1) ;
/* merge, to form one intra communicator */ CHK(MPI_Intercomm_merge(intercomm, 0, &intracomm)) ;
printf("SERVER: merged with client %d\n", i+1) ;
CHK(MPI_Comm_size(intracomm, &size)) ; CHK(MPI_Comm_rank(intracomm, &rank)) ;
printf("SERVER: after merging with client %d: size=%d rank=%d\n", i+1, size, rank) ; } } /* end server */
/* client */ if(role == 0) { printf("CLIENT: on node '%s'\n", hostname) ;
fp = fopen("server_port_name.txt", "r") ; if(fp == NULL) { fprintf(stderr, "fopen failed: %s\n", strerror(errno)) ; exit(1) ; } fscanf(fp, "%s", server_port_name) ; fclose(fp) ;
printf("CLIENT: attempting to connect to server on port=%s\n", server_port_name) ;
/* connect to the server */ CHK(MPI_Comm_connect (server_port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm)) ;
printf("CLIENT: connected to server on port\n") ;
/* merge the server and client to one intra communicator */ CHK(MPI_Intercomm_merge(intercomm, 1, &intracomm)) ;
printf("CLIENT: merged with existing intracomm\n") ;
printf("CLIENT: after merging, new comm: size=%d rank=%d\n", size, rank) ;
for (i = rank ; i < num_clients ; i++) { /* client performs a collective accept */ CHK(MPI_Comm_accept(server_port_name, MPI_INFO_NULL, 0, intracomm, &intercomm)) ;
/* merge the two intra comms back to one communicator */ CHK(MPI_Intercomm_merge(intercomm, 0, &intracomm)) ;
printf("CLIENT: merged with existing members\n") ;
printf("CLIENT: new size after merging with existing members: size=%d rank=%d\n", size, rank) ; }
} /* end client */
printf("After fusion: size=%d rank=%d\n", size, rank) ;
if(rank == 0) { msg_count = num_clients ;
while(msg_count) { CHK(MPI_Recv(buff, 255, MPI_CHAR, MPI_ANY_SOURCE, MPI_ANY_TAG, intracomm, &status)) ;
printf("Received hello msg from '%s'\n", buff) ; msg_count-- ; } } else { /* all ranks > 0 */
CHK(MPI_Send(hostname, strlen(hostname) + 1, MPI_CHAR, 0, TAG, intracomm)) ; }
CHK(MPI_Finalize()) ;
fprintf(stderr, "Rank %d is exiting\n", rank); return 0 ; }
At 2015-01-24 10:43:07, "haozi" <[email protected]> wrote: Thanks, Bland and Lu.
You are right. These functions (such as MPI_Comm_accept, MPI_Comm_connect, MPI_Intercomm_merge) can help me to get a new intra-communicator which contains ALL MPI processes.
Now, I have a more complicated example: I have a server and a client. After they merge into an intra-communicator by using connect/accept/merge fucntions, another client would plant to join them, too. I thought that the code is simular, but the code CAN'T work: Second client CAN'T connect. The new comm CAN'T accept. They all BLOCK.
As you see, the second client BLOCKs at MPI_Comm_connect, and processes of newcomm BLOCK at MPI_Comm_accept. What's Wrong with my code?
//server #include "mpi.h" int main(int argc, char *argv[]) { MPI_Comm client, client2, newcomm, newcomm2; MPI_Status status; char port_name[MPI_MAX_PORT_NAME]; char port_name2[MPI_MAX_PORT_NAME]; int size, again, rank, myrank;
MPI_Init(&argc, &argv); MPI_Open_port(MPI_INFO_NULL, port_name);//OK
MPI_Comm_accept(port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD,&client);//OK
MPI_Intercomm_merge(client,11,&newcomm);//OK
MPI_Barrier(newcomm);//OK
MPI_Open_port(MPI_INFO_NULL, port_name2);// OK
MPI_Comm_accept(port_name2, MPI_INFO_NULL, 0, newcomm,&client2);// BLOCK here, Wath's wrong?
MPI_Intercomm_merge(client2,12,&newcomm2);
MPI_Barrier(newcomm2);
MPI_Close_port(port_name); MPI_Comm_disconnect(&client); MPI_Close_port(port_name2); MPI_Comm_disconnect(&client2);
MPI_Finalize(); return 0; }
//first client #include "mpi.h" int main( int argc, char **argv ) { MPI_Comm server,newcomm,newcomm2,client2; char port_name[MPI_MAX_PORT_NAME]; char port_name2[MPI_MAX_PORT_NAME]; int size,rank;
MPI_Init( &argc, &argv );
strcpy( port_name, argv[1] ); MPI_Comm_connect( port_name, MPI_INFO_NULL, 0, MPI_COMM_SELF,&server );//OK
MPI_Intercomm_merge(server,11,&newcomm);//OK
MPI_Open_port(MPI_INFO_NULL, port_name2);//OK
MPI_Close_port(port_name2); MPI_Comm_disconnect(&client2); MPI_Comm_disconnect( &server ); MPI_Finalize(); return 0; }
//second client #include "mpi.h" int main( int argc, char **argv ) { MPI_Comm server,newcomm; char port_name[MPI_MAX_PORT_NAME]; int size,rank;
strcpy( port_name, argv[1] );//OK
MPI_Comm_connect( port_name, MPI_INFO_NULL, 0, MPI_COMM_SELF,&server );// BLOCK here, Wath's wrong?
MPI_Comm_size(MPI_COMM_WORLD, &size);
At 2015-01-23 23:14:06, "Wesley Bland" <[email protected]> wrote: The size of MPI_COMM_WORLD will never change. That communicator is set at initialization time and is not ever modified. However, when you finish connect/accept, you get a new communicator which you can merge into an intra-communicator which functions exactly like MPI_COMM_WORLD. Don’t be attached to the variable name MPI_COMM_WORLD. It’s just a variable and you can use a different one with very little extra work.
Thanks, Wesley
On Thu, Jan 22, 2015 at 6:14 PM, haozi <[email protected]> wrote: Thanks, Lu. My simple code is as following. //server #include "mpi.h"
int main(int argc, char *argv[]) { MPI_Comm client; MPI_Status status; char port_name[MPI_MAX_PORT_NAME]; int size, again;
MPI_Init(&argc, &argv); MPI_Comm_size(MPI_COMM_WORLD, &size); MPI_Open_port(MPI_INFO_NULL, port_name); printf("server port_name is %s\n\n", port_name); MPI_Comm_accept(port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD,&client); MPI_Comm_size(MPI_COMM_WORLD, &size); printf("At server, comm_size=%d @ MPI_COMM_WORLD=%x, Client_World=%x\n",size,MPI_COMM_WORLD, client); MPI_Comm_size(client, &size); printf("At server, client_size=%d @ MPI_COMM_WORLD=%x, Client_World=%x\n",size,MPI_COMM_WORLD, client);
MPI_Comm_disconnect(&client); MPI_Finalize(); return 0; }
//client #include "mpi.h"
int main( int argc, char **argv ) { MPI_Comm server; char port_name[MPI_MAX_PORT_NAME]; int size;
MPI_Init( &argc, &argv ); strcpy( port_name, argv[1] ); printf("server port name:%s\n",port_name); MPI_Comm_connect( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD,&server ); MPI_Comm_size(MPI_COMM_WORLD, &size); printf("At client, comm_size=%d @ MPI_COMM_WORLD=%x, Server_World=%x\n",size,MPI_COMM_WORLD,server); MPI_Comm_size(server, &size); printf("At client, server_size=%d @ MPI_COMM_WORLD=%x, Server_World=%x\n",size,MPI_COMM_WORLD,server);
The run command is as following. mpiexec -n 1 ./server mpiexec -n 1 ./client
BUT, the SIZE is 1, NOT 2.
My question is as before: How does the size of MPI_COMM_WORLD change to 2 ?
At 2015-01-23 00:30:43, "Huiwei Lu" <[email protected]> wrote: You may take a look at MPI_Comm_accept and MPI_Comm_connect, which will connect a new client process to a server process. See Chap. 10 of MPI 3.0 standard (www.mpi-forum.org/docs/mpi-3.0/mpi30-report.pdf) for a detail example.
-- Huiwei Lu Postdoc Appointee Mathematics and Computer Science Division Argonne National Laboratory http://www.mcs.anl.gov/~huiweilu/
On Thu, Jan 22, 2015 at 9:41 AM, haozi <[email protected]> wrote: Hi, guys.
This web page (http://wiki.mpich.org/mpich/index.php/PMI_v2_Design_Thoughts) says: Singleton init. This is the process by which a program that was not started with mpiexec can become an MPI process and make use of all MPI features, including MPI_Comm_spawn, needs to be designed and documented, with particular attention to the disposition of standard I/O. Not all process managers will want to or even be able to create a new mpiexec process, so this needs to be negotiated. Similarly, the dispostion of stdio needs to be negotiated between the singleton process and the process manager. To address these issues, a new singleton init protocol has been implemented and tested with the gforker process manager.
I am very interested in this function. Can this function solve the following question: At beginning, the MPI job uses the mpiexec commond to start three MPI processes. That is to say, there are three MPI processes in MPI_COMM_WORLD. At some time, the job find itself to need another MPI process to cooperate the three MPI processes. So the question is: Could PMI help an non-MPI process to become a MPI process of the current MPI_COMM_WORLD? That is to say, Could the non-MPI process use the PMI function to become a member process of the current MPI job which would have FOUR MPI processes in MPI_COMM_WORLD?
Is there some method to solve question? Is anybody have some example?
Thandks!!!
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
participants (1)
haozi
