Re: [mpich-discuss] reading from a read only directory
Personally, I'd address the paranoia by saving a copy of your files into a read-only directory. Since I know where you're running, I can say that we should be able to afford the extra storage. If not, let me know and I'll address it. And note also that NERSC $SCRATCH is not backed up, so the safe place to story anything valuable is $HOME. I'm not sure about project directories but I imagine there are docs on this. It would be nice if it were possible to do read-only MPI-IO in a read-only directory. I don't have a clue what the technical challenges are. Can you not make just the files read-only but let new files be created in the directory? Jeff On Wed, Nov 27, 2013 at 11:32 PM, Geoffrey Irving <[email protected]> wrote:
I got the following error trying to slurp in a large file (slice-17.pentago) with MPI_File_read_ordered:
rank 0: pentago/mpi/io.cpp:read_sections:397: MPI_File_read_ordered(file,raw.data(),raw.size(),MPI_BYTE,MPI_STATUS_IGNO ADIOI_CRAY_OPEN(102): Access denied to file all-1/.slice-17.pentago.shfp.670064
The directory all-1 was read only due to paranoia over accidentally deleting expensively obtained data. Looking at ADIOI_Shfp_fname in the mpich source, it looks like this error is intentional: the shared file pointer routines generate temporary files in the same directory as the read-from file. I couldn't find any attempts at recovery if the file cannot be written in that place. This behavior doesn't seem to have changed since the beginning of the git repository.
Is my reading of the code correct: MPI_File_read_ordered can't be used on a file in a read only directory?
I can see the motivation for this in the case of noncollective shared routines: since the other processes aren't necessarily doing any MPI at the moment, the only way to synchronize is through the file system. And because there might be all sorts of different filesystems in operation, the easiest way to ensure that we're touching the right one is use the same directory. I can't imagine any reasonable use of the noncollective shared routines, but maybe that's a different discussion. Is this an unfortunate leak between broken routines which need questionable trickery and perfectly good routines like MPI_File_read_ordered?
Thanks, Geoffrey _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected]
participants (1)
Jeff Hammond
