Re: [mpich-discuss] optimization of MPI_Alltoall(..)
Hi Daniel, thanks a lot for this comparisons test. I do not have access to the Inifiniband setup, so your numbers will help me to build the case that I need one locally. Change to inifiniband is obviously the most promising way to increase the throughput. Would it be to much to ask you run the my code on more than 32 cores (if you have that many)? At some point Inifiniband will saturate, adding more cores will not translate on the larger 'speed' in MB/sec. I'm curious where is this limit. Thanks you very much Jan P.S. due to hardcoded dimensions my code would run as is up to 64 cores. For a higher core count this 2 variables need to be modified so they are divisible by the core count: int NchXtot=9*5*7*64*2, NchTtot=9*5*7*64 ; Jan Quoting "Kokron, Daniel S. (GSFC-606.2)[Computer Sciences Corporation]" <[email protected]>:
Jan,
Here is some output from your code on a cluster that uses FDR Infiniband instead of 1Gbit Ethernet. I also used the vendor MPI which is SMP aware.
participants (1)
Jan T. Balewski
