Re: [mpich-discuss] How to make a non-MPI process to become a MPI process of MPI_COMM_WORLD?
Also, I run server at node1, and run client at node2, and run client at node3, and ... These nodes have different IP. Can MPI publish/loopup work ??? At 2015-01-26 08:07:19, "haozi" <[email protected]> wrote: Yes, I run the example with mpiexec. At 2015-01-26 03:26:21, "Balaji, Pavan" <[email protected]> wrote:
Using dynamic processes is not supported in MPICH for singleton init. Can you try running it with mpiexec?
Also, note that you should be using MPI publish/lookup functions instead of writing to a file yourself.
-- Pavan
On Jan 25, 2015, at 5:26 AM, haozi <[email protected]> wrote:
Thanks, Balaji.
server_port_name.txt is built by the example, not by user.
At 2015-01-25 19:24:28, "Balaji, Pavan" <[email protected]> wrote:
On Jan 25, 2015, at 5:04 AM, haozi <[email protected]> wrote: Hello, Balaji.
The example from OpenMPI is attached.
server_port_name.txt is missing.
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
haozi
