Re: [mpich-discuss] mpich2 1.5: failing tests src/mpe2
Have you tried updating to the latest version of MPICH? Our current version is 3.1.3. The version you are using is years old so we'll have a hard time helping you fix any issues. Thanks, Wesley On Tue, Jan 13, 2015 at 1:13 PM, Giordano Lipari < [email protected]> wrote:
I have installed mpchi2-1.5 in my Linux desktop (Ubuntu 12.04 LTS 64-bit) with the standard command sequence
sudo ./configure --prefix=$MOUNTDIR sudo make sudo make install sudo make check
The following 9 tests of the check in src/mpe2 fail: *** Test C program with the MPI tracing library .......................... No. *** Test C program with the MPI logging library .......................... No. *** Test C program with the MPI and manual logging libraries ............. No. *** Test F77 program with the MPI and manual logging libraries ........... No. *** Test C program with the MPI animation library ........................ No. *** Test C program with the X11 graphics library ......................... No. *** Test F77 program with the X11 graphics library ....................... No. *** Test C program with the MPI collective/datatype checking library ..... No. *** Test F77 program with the MPI collective/datatype checking library ... No.
The entire stdout and stderr outputs are enclosed as attachment. My question is whether this is the regular behaviour and, if not, how I fix this. Thanks for helping me out!
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
