Re: [mpich-discuss] credentials for mpiexec -f machinefile
On Apr 23, 2014, at 5:10 PM, "Antonio J. Peña" <[email protected]> wrote:
No, what I meant was doing "ssh localhost", but now I look at your logs again, it may be a problem of your DNS configuration. mpi-966f395e-bbb1-4a20-8cbc-c10081e91244 seems to be unable to resolve the IP address of mpi-be6bebee-55e3-4901-a5bb-637395ba46f6. Take a look at your /etc/hosts files in both hosts.
Right, I just figured that out as well. When VM's are launched the get assigned this funny names, not matching the DNS names. So I have manually adjusted the content of this 3 files (I run on SL6.5) vi /etc/hostname vi /etc/sysconfig/network vi /etc/hosts so the DNS name , public IP, and hostname --fqd return the same info, e.g. [cosy11@oswrk210 mpich-3.1]$ hostname --fqd oswrk210.lns.mit.edu Now the command below does not crashes but hangs for many minutes, eventually time-outing. So looks like I need to open port 60568 , right? After I shut down fire wall on IP=210 it complain abut port 45895 Next I shut down firewall in IP=207 and it complained abut new port 35167 Finally I shut down firewall between VM (on the openStack controller) and … IT WORKED: [cosy11@oswrk210 mpich-3.1]$ mpiexec -f machinefile2 -n 4 ./examples/cpi Process 0 of 4 is on oswrk210.lns.mit.edu Process 3 of 4 is on oswrk207.lns.mit.edu Process 1 of 4 is on oswrk210.lns.mit.edu Process 2 of 4 is on oswrk207.lns.mit.edu pi is approximately 3.1415926535899028, Error is 0.0000000000001097 wall clock time = 0.003602 QUESTION: Can you tell me what ports I need to have open on the master & worker VMs for mpiexec to distribute work on them? Jan
participants (1)
Jan Balewski
