Re: [mpich-discuss] Does MPICH implements polling mechanism on MPI_Recv?
On Sep 22, 2014, at 11:42 PM, Anatoly G <[email protected]> wrote:
Thank you very much.
I'm using MPICH 3.1.
The application purpose is continue execution until at least Master process is live. The assumption is that processes can fail, but no more than single failure at a time. In this case survived processes must continue "like a Terminator". (-: In run-time I can't execute "manually" MPI_Test on all requests, it's too heavy. I have a network traffic ~ 400-500 Mb/s.
Implementation: I set -disable-auto-cleanup flag to activate Fault tolerance. All my processes activate MPI_Irecv on other processes and then execute MPI_Waitany on all active requests. When data arrives correctly, I process it and execute new MPI_Irecv on source process. If MPI_Waitany returns error (some process failed) I recognize failed rank and stop communication with it on application level (no more Sends & Recvs to it). In this mode system continues execution with survived processes. I don't use any collective operations, I simulate them using MPI_Irecv & MPI_Isend + MPI_Waitany or MPI_Waitall (returns error if some process failed).
I think it's ugly solution, but I can't think on any more elegant solution. Any other solution at all would be welcome.
You could use MPI_Testall/any if you’d like, but of course that may not fit your application usage. Overall, I don’t see an issue with your model.
The problem in "ready" state, when there is almost only waiting 3-4 messages may be received by process. In this state all CPUs are busy by executing polling mechanism.
That’s to be expected. While waiting for messages using MPI_Wait, it’s expected that nothing else is happening (unless you’re using threads as well, which it appears that you aren’t). That puts MPI into a busy wait to receive the message. As I mentioned previously, if you want to poll less frequently, you’ll have to use some flavor of MPI_Test. Out of curiosity, what is the issue with using 100% of the CPU? If you’re not using it for your application (which it appears that you aren’t since you’re calling MPI_Wait), what difference does it make if MPI uses all of it? Thanks, Wesley
Regards, Anatoly.
On Mon, Sep 22, 2014 at 4:46 PM, Wesley Bland <[email protected] <mailto:[email protected]>> wrote: Which version of MPICH are you using?
Which fault tolerance features are you using? Fault tolerance is currently undergoing some changes and has different features than it used to have.
AFAIK, neither version of FT has been tested with ch3:sock. It’s possible that it will work, but FT is still a very experimental feature and hasn’t been widely tested.
If you want to avoid polling more, you can use non-blocking receive calls to post a receive and poll the system yourself periodically (using MPI_TEST). This will give your application an opportunity to do something else while waiting for the receives to complete.
Thanks, Wesley
On Sep 22, 2014, at 8:30 AM, Anatoly G <[email protected] <mailto:[email protected]>> wrote:
Dear MPICH. I have a problem with poling MPICH mechanism. I'm working on cluster. There are 2-4 processes on each computer (I can't execute single process per computer because of application requirements). My system has 2 states: Ready - slaves listen to master (but no data flow) Run - masters start communication, then there is data flow. When system in ready state (all processes except master executed MPI_Recv requests on master) but Master process still net sending data I see CPU usage > 100% (more than 1 core used) per process. When 4 processes are in ready state (waiting for data) computer begins to slow down other processes, I think because of polling. I tried to build MPICH with --with-device=ch3:sock, then I get 0% CPU usage in ready state, but I have a problem with Fault tolerance feature. My questions are: 1) Is such behavior expected that build with --with-device=ch3:sock causes Fault tolerance not work? Does Fault tolerance based on polling mechanism? 2) Can I change polling rate to reduce CPU payload? I understand that penalty is transfer rate slow down. 3) Can I use any other MPI APIs to check if message from master is arrived w/o activating polling mechanism?
Regards, Anatoly.
On Thu, May 8, 2014 at 3:57 PM, Balaji, Pavan <[email protected] <mailto:[email protected]>> wrote:
This is expected. Currently, the only way to not have MPICH poll is to configure with --with-device=ch3:sock. Please note that this can cause performance loss (the polling is helpful for performance in the common case).
We are planning to allow this in the default build as well in the future.
— Pavan
On May 8, 2014, at 7:54 AM, Anatoly G <[email protected] <mailto:[email protected]>> wrote:
Dear MPICH forum. I created an endless MPI program. In this program each process calls MPI_Recv from other process, w/o any MPI_Send. When I execute this program I see each process takes ~ 100% CPU core. Is this behavior (I suppose polling) is normal? May I reduce MPI_Recv CPU penalty?
Regards, Anatoly. <mpi_polling.cpp>_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
