Re: [mpich-discuss] Segmentation fault (signal 11) and Exit code 139
Not an MPICH problem. Contact WRF support. Jeff Sent from my iPhone On Jul 9, 2013, at 2:09 AM, Zheng Li <[email protected]> wrote: Dear All, I tried to run the default January 2000 Case (the East Coast Winter Storm of January 24-25, 2000) in WRF v3.5, and failed when running wrf.exe. The error is as follows: [sl@sl0 em_real]$ mpirun -np 4 ./wrf.exe starting wrf task 0 of 4 starting wrf task 1 of 4 starting wrf task 2 of 4 starting wrf task 3 of 4 =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 139 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions Does someone have idea of resolving this issue? Thanks in advance. Lee <[email protected]> _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
