Re: [mpich-discuss] mpich 3.0.4 build problem
Likewise for F77 and FC. Both should be set to gfortran-mp-4.7 if you want consistency. -- Pavan On 05/03/2013 01:24 PM US Central Time, Rajeev Thakur wrote:
In addition to FCFLAGS if you had set F77FLAGS to -m64, it probably would have worked in the third case.
On May 3, 2013, at 1:17 PM, Thomas Evans wrote:
Operating System OSX 10.8.3 Xcode v4.6.1 MPICH 3.0.4
macports % port list automake libtool autoconf gcc47 automake @1.13.1 devel/automake libtool @2.4.2 devel/libtool autoconf @2.69 devel/autoconf gcc47 @4.7.3 lang/gcc47
========================== My first attempt ============================= setenv CC "gcc-mp-4.7 -m64" setenv FC "gfortran-mp-4.7 -m64" setenv F77 "gfortran-mp-4.7 -m64" setenv F90 "gfortran-mp-4.7 -m64" ./configure --prefix=$HOME/mpi3gnu473 --enable-fc --disable-cxx --with-device=ch3:nemesis ... configure: ===== done with src/openpa configure ===== ... configure: error: F90 and F90FLAGS are replaced by FC and FCFLAGS respectively in this configure, please unset F90/F90FLAGS and set FC/FCFLAGS instead and rerun configure again
Remarks: While odd, this is at least says what it wants.
========================== My second attempt ============================= unsetenv F77 unsetenv F90 ./configure --prefix=$HOME/mpi3gnu473 --enable-fc --disable-cxx --with-device=ch3:nemesis ... configure: ===== done with src/openpa configure ===== ... configure: error: **** Incompatible Fortran and C Object File Types! **** F77 Object File Type produced by "gfortran -O2" is : : Mach-O object i386. C Object File Type produced by "gcc-mp-4.7 -m64 -O2" is : : Mach-O 64-bit object x86_64.
Remark: sometimes I see "gfortran", sometimes I see "gfortran-mp-4.7 -m64"
========================== My third attempt =============================
setenv FC "gfortran-mp-4.7" setenv FCFLAGS "-m64" ./configure --prefix=$HOME/mpi3gnu473 --enable-fc --disable-cxx --with-device=ch3:nemesis ... configure: ===== done with src/openpa configure ===== ... configure: error: **** Incompatible Fortran and C Object File Types! **** F77 Object File Type produced by "gfortran -O2" is : : Mach-O object i386. C Object File Type produced by "gcc-mp-4.7 -m64 -O2" is : : Mach-O 64-bit object x86_64. Remark: Well, that didn't help.
========================== My workaround ============================= In the end I created a csh script called gfortran at the start of my path and simply made it execute gfortran-mp-4.7 -m64 $argv This built okay and runs just fine.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
