Re: [mpich-discuss] MPICH3 Problem
Correct. libpgmp.so should be from your PGI compiler installation. — Sangmin On Feb 3, 2015, at 5:53 PM, Abhishek Bhat <[email protected]<mailto:[email protected]>> wrote: Sangmin, I have installed MPICH on shared drive but PGI fortran is installed on /opt/pgi which node do not have access. I am assuming that is the issue currently. I am trying to re-install PGI on the shared drive to see if that will fix the problem. Just to confirm libpgmp.so is not mpich file correct? Thank You Abhishek …………………………………………………………………………………………………. Abhishek Bhat, PhD, EPI, Senior Consultant From: Seo, Sangmin [mailto:[email protected]] Sent: Tuesday, February 03, 2015 5:50 PM To: <[email protected]<mailto:[email protected]>> Subject: Re: [mpich-discuss] MPICH3 Problem Hi Abhishek, As the error message says, it looks that the node running the application doesn’t have libpgmp.so. Can you confirm whether the node has libpgmp.so and whether LD_LIBRARY_PATH is correctly set on the node in case that it has libpgmp.so? Best regards, Sangmin On Feb 3, 2015, at 5:31 PM, Abhishek Bhat <[email protected]<mailto:[email protected]>> wrote: HI All, I installed MPICH3 on a master terminal along with PGI Fortran. Then used MPICH3 and PGI to compile my software. When I run the program on the master terminal only I do not have any error messages but when I am trying to run them on one of the nodes, I am getting following message error – /home/Earth/MODELS/camx/src_611/CAMx.v6.11.MPICH3.pgfomp: error while loading shared libraries: libpgmp.so: cannot open shared object file: No such file or directory /home/Earth/MODELS/camx/src_611/CAMx.v6.11.MPICH3.pgfomp: error while loading shared libraries: libpgmp.so: cannot open shared object file: No such file or directory =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 5200 RUNNING AT node3 = EXIT CODE: 127 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== [proxy:0:0@Earth] HYD_pmcd_pmip_control_cmd_cb (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/pm/pmiserv/pmip_cb.c:885): assert (!closed) failed [proxy:0:0@Earth] HYDT_dmxu_poll_wait_for_event (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/tools/demux/demux_poll.c:76): callback returned error status [proxy:0:0@Earth] main (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@Earth] HYDT_bscu_wait_for_completion (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/tools/bootstrap/utils/bscu_wait.c:76): one of the processes terminated badly; aborting [mpiexec@Earth] HYDT_bsci_wait_for_completion (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion [mpiexec@Earth] HYD_pmci_wait_for_completion (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:218): launcher returned error waiting for completion [mpiexec@Earth] main (/home/Earth/MODELS/mpi/mpich-3.1.3/src/pm/hydra/ui/mpich/mpiexec.c:344): process manager error waiting for completion The /home/Earth is shared and mapped on all nodes Any help is much appreciated. Thank You Abhishek …………………………………………………………………………………………………. Abhishek Bhat, PhD, EPI, Senior Consultant _________________________________________________________________________ The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer. _________________________________________________________________________ _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _________________________________________________________________________ The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer. _________________________________________________________________________ _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Seo, Sangmin
