Re: [mpich-discuss] Using MPICH in Python breaks Fortran MPI_IN_PLACE
Has Lisandro provided any feedback on this anywhere? I agree with Hui. This appears to be an artifact of the way MPI uses magic values for MPI_IN_PLACE and how those get encoded in binaries. I naively speculate that MPICH could encode the magic values differently to work around this, but that would likely break ABI compatibility, at least on the Fortran side. Jeff On Wed, Jun 10, 2020 at 3:31 PM Zhou, Hui via discuss <[email protected]> wrote:
I am not sure this is an issue for mpich. Seems more to be an issue of `mpi4py`. The issue is exactly as you suspected -- `libmpifort.so` need be loaded before `libmpi.so`, or the external symbol in `libmpifort.so` won’t get resolved.
It works if you load something linked to libmpifort first or load everything with RTLD_GLOBAL.
Seems plausible. I don’t have any better idea other than fixing `mpi4py` so it always load `libmpifort.so` first.
-- Hui Zhou
*From: *Patrick McNally via discuss <[email protected]> *Reply-To: *"[email protected]" <[email protected]> *Date: *Wednesday, June 10, 2020 at 1:09 PM *To: *"[email protected]" <[email protected]> *Cc: *Patrick McNally <[email protected]> *Subject: *Re: [mpich-discuss] Using MPICH in Python breaks Fortran MPI_IN_PLACE
I hate to bug, but this is a pretty serious issue. I suspect it is why we get segfaults trying to use similar variables like MPI_STATUSES_IGNORE. Any insight would be appreciated.
Patrick
On Wed, May 27, 2020 at 10:25 AM Patrick McNally <[email protected]> wrote:
Our application consists primarily of a Python head calling into Fortran routines to do the heavy lifting. We have never been able to successfully use MPI_IN_PLACE in Fortran but weren't sure why. Recently, we discovered that it works fine in standalone Fortran code and is only broken when the Fortran code is run through our Python modules.
The issue appears to be related to having code that only links to the C libmpi library loaded first and with RTLD_LOCAL, as happens when we load mpi4py. It works if you load something linked to libmpifort first or load everything with RTLD_GLOBAL. I'm assuming this has something to do with how MPICH tests the address of MPIR_F08_MPI_IN_PLACE but I don't understand SO loading well enough to fully grasp the issue. Below is some standalone code to show the issue. I'd appreciate any insight you can provide into why this is happening.
Relevant system details: RHEL 7.8 Python 2.7 GCC 7.3.0 MPICH 3.3.2 (and 3.2)
The below files are also available towards the end of the bug report at the following link:
https://bitbucket.org/mpi4py/mpi4py/issues/162/mpi4py-initialization-breaks-...
Patrick
makefile ----------- libs = testc.so testf.so all: $(libs)
testc.so: testc.c mpicc -shared -fPIC $< -o $@
testf.so: testf.f90 mpifort -shared -fPIC $< -o $@
clean: $(RM) $(libs)
testc.c --------- #include <stddef.h> #include <stdio.h> #include <mpi.h>
extern void initc(void); extern void testc(void);
void initc(void) { MPI_Init(NULL,NULL); }
void testc(void) { int val = 1; MPI_Allreduce(MPI_IN_PLACE, &val, 1, MPI_INT, MPI_SUM, MPI_COMM_WORLD); printf("C val: %2d\n",val); }
testf.f90 ----------- subroutine initf() bind(C) use mpi integer ierr call MPI_Init(ierr) end subroutine initf
subroutine testf() bind(C) use mpi integer ierr integer val val = 1 call MPI_Allreduce(MPI_IN_PLACE, val, 1, MPI_INTEGER, MPI_SUM, MPI_COMM_WORLD, ierr) print '(A,I2)', 'F val: ', val end subroutine testf
test.py --------- from ctypes import CDLL, RTLD_LOCAL, RTLD_GLOBAL
mode = RTLD_LOCAL cfirst = True
if cfirst: # it does not work! libc = CDLL("./testc.so", mode) libf = CDLL("./testf.so", mode) else: # it works! libf = CDLL("./testf.so", mode) libc = CDLL("./testc.so", mode)
libc.initc.restype = None libc.testc.argtypes = [] libf.initf.restype = None libf.testf.argtypes = []
libc.initc() libc.testc() libf.testf()
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
