Re: [mpich-discuss] Fwd: Windows and mpicc
Hi, The LANG setting might be related to the unrecognized characters in the makefile. Looks like the build system is not able to find the definition for sighandler_t (usually found in signal.h). This should have been handled at configure time. You should be able to find MPICH2 configure options in the MPICH2 installers guide (http://www.mpich.org/documentation/guides/). Regards, Jayesh ----- Original Message ----- From: "John Mole" <[email protected]> To: "Jayesh Krishna" <[email protected]> Sent: Monday, November 26, 2012 8:54:42 AM Subject: RE: [mpich-discuss] Fwd: Windows and mpicc Hi Jayesh, The LANG environment variable refers to localisation, so is not relevant. On looking closely at the code, I found some bugs in dbxerr.c.in. I made the following changes to get it to compile: Line 406: #define SIG_HANDLER_PROTOTYPE sighandler_t Changed to: #define SIG_HANDLER_PROTOTYPE int Line 409: int sig Changed to: int sig; I am still trying to resolve the Win32 memory issue. Meanwhile, can you let me have a full list of the mpich config options please? Regards, John Mole -----Original Message----- From: Jayesh Krishna [mailto:[email protected]] Sent: 20 November 2012 14:42 To: Mole, John Cc: [email protected] Subject: Re: [mpich-discuss] Fwd: Windows and mpicc Hi, A google search suggests that your setting for LANG environment variable may be incorrect. Can you check what it is (Can you set it to say "LANG=C" and see if it works)? Regards, Jayesh ----- Original Message ----- From: "John Mole" <[email protected]> To: "Jayesh Krishna" <[email protected]> Sent: Monday, November 19, 2012 9:37:49 AM Subject: RE: [mpich-discuss] Fwd: Windows and mpicc Hi Jayesh, I have checked dbxerr.c in hex and there are no DOS characters - make output attached. I don't want to disable MPE so I need to solve this problem somehow. I will post on the Cygwin forum about the memory issue as you suggested. Regards, John Mole -----Original Message----- From: Jayesh Krishna [mailto:[email protected]] Sent: 12 November 2012 16:32 To: [email protected] Cc: Mole, John Subject: Re: [mpich-discuss] Fwd: Windows and mpicc Hi, Looks like you have compile time errors for mpe because of DOS characters. If you are not planning to use MPE you can disable it (Specify "--disable-mpe" during configure time). The error that stopped the build looks like a Cygwin error (Unable to allocate enough memory for the linker). I have seen these errors when packages are updated (A "rebase" sometimes solves the problem). I would recommend posting your issue on a Cygwin forum. Can you try running the build again (after disabling MPE at compile time) after you fix the Cygwin issue? Regards, Jayesh ----- Original Message ----- From: "Jayesh Krishna" <[email protected]> To: [email protected] Sent: Friday, November 9, 2012 2:58:06 PM Subject: [mpich-discuss] Fwd: Windows and mpicc FYI ----- Forwarded Message ----- From: "John Mole" <[email protected]> To: "Jayesh Krishna" <[email protected]> Sent: Friday, November 9, 2012 10:25:19 AM Subject: RE: [mpich-discuss] Windows and mpicc Hi Jayesh, Thanks. I did as you suggested. On the configure stage, I had to convert all the configure-related files to change the end of line characters to UNIX rather than DOS. The Cygwin version of BASH seems to be very picky about this. Eventually I managed to persuade the ./configure to work (output attached). However, the make stage failed with various errors (output attached). I have also included a list of the environmental variables, which may be relevant. Any advice on how to proceed would be much appreciated. Regards, John Mole -----Original Message----- From: Jayesh Krishna [mailto:[email protected]] Sent: 07 November 2012 15:50 To: Mole, John Cc: [email protected] Subject: Re: [mpich-discuss] Windows and mpicc Hi, There are two ways to install MPICH2 on Windows - (1) Using the Windows installers (2) Downloading MPICH2 source and compiling it under Cygwin. If you install MPICH2 using the Windows msi installers mpicc is not installed (Users typically compile their programs using Visual Studio, Intel Windows compilers etc). Since you are working in the Cygwin environment please uninstall MPICH2 and download the MPICH2 source from the link below and install (configure/make/make install - like you would install software on a unix-like/cygwin system) it. Regards, Jayesh ----- Original Message ----- From: "John Mole" <[email protected]> To: "Jayesh Krishna" <[email protected]> Sent: Wednesday, November 7, 2012 6:49:59 AM Subject: RE: [mpich-discuss] Windows and mpicc Hi Jayesh, I have already downloaded and installed the Windows version but there is no sign of mpicc (or the Fortran equivalent) in the /bin folder hence my original query. Regards, John Mole -----Original Message----- From: Jayesh Krishna [mailto:[email protected]] Sent: 06 November 2012 15:27 To: [email protected] Cc: Mole, John Subject: Re: [mpich-discuss] Windows and mpicc Hi, mpicc is the compiler wrapper that is installed with MPICH2 (or an MPI library suite). You can download the source and install MPICH2 from the MPICH2 website (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downlo...). Regards, Jayesh ----- Original Message ----- From: "John Mole" <[email protected]> To: [email protected] Sent: Monday, November 5, 2012 4:40:58 PM Subject: [mpich-discuss] Windows and mpicc I am currently porting a mathematical modelling application from Ubuntu to Windows. I am fairly new to Linux. I am mostly working in Cygwin which emulates the Linux environment in Windows. I have installed MPICH2 on Windows and have set the necessary paths. In trying to make Parmetis in Cygwin I get the error ‘mpicc not found’. So I am trying to track down mpicc. I don’t know where it comes from. Is it from GNU or MPICH or where? How do I get hold of it? I would be most grateful if someone could provide guidance. Thanks, John Mole _______________________________________________ mpich-discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss _______________________________________________ mpich-discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
participants (1)
Jayesh Krishna
