Re: [mpich-discuss] MPI_Comm_spawn crosses node boundaries
Are you using mpiexec or srun when initially launching your job? Hydra (mpiexec) should support the "host" info key, but I'm not sure if srun will. Ken On 1/28/22, 10:41 AM, "Mccall, Kurt E. (MSFC-EV41) via discuss" <[email protected]> wrote: Hi, Running MPICH under Slurm, MPI_Comm_spawn unexpectedly creates new processes on any and all of the nodes that Slurm allocates to the job. I would like it to only create new processes locally on the node that called MPI_Comm_spawn. I’ve tried passing MPI_Comm_spawn an info struct created like this: MPI_Info info; MPI_Info_create(&info); MPI_Info_set(info, "host", host_name); MPI_Info_set(info, "bind_to", "core"); where hostname = “n001” or even the full name “n001.cluster.pssclabs.com” but that doesn’t prevent the problem. Any suggestions? Thanks, Kurt
participants (1)
Raffenetti, Ken
