Re: [mpich-discuss] no man pages for mpich-3.1.3?
Hi Huiwei,
The latest mpich nightly built is mpich-master-v3.1.3-12-gc11ccde6.tar.gz.
I have tested it on my laptop and it installed the man page.
$ ./configure â?"prefix=/sandbox/install $ ls /sandbox/install/share/man man1 man3
Could you try again?
Yes, everything is fine for mpich-master-v3.1.3-13-gf0151661. Thank you very much for your help. Kind regards Siegmar
â?" Huiwei
On Oct 15, 2014, at 1:29 AM, Siegmar Gross <[email protected]> wrote:
Hi Pavan,
thank you very much for your answer. Today I installed mpich-master-v3.1.3-9-g4d07079d, but I still have no man page directory.
tyr mpich-3.1.3 177 ls -l /export2/prog/*/mpich-3.1.3_64_*/share | \ grep -e : -e drwx /export2/prog/Linux_x86_64/mpich-3.1.3_64_cc/share: drwxr-xr-x 3 root root 512 Oct 15 07:40 doc /export2/prog/Linux_x86_64/mpich-3.1.3_64_gcc/share: drwxr-xr-x 3 root root 512 Oct 15 07:26 doc /export2/prog/SunOS_sparc/mpich-3.1.3_64_cc/share: drwxr-xr-x 3 root root 512 Oct 15 08:23 doc /export2/prog/SunOS_sparc/mpich-3.1.3_64_gcc/share: drwxr-xr-x 3 root root 512 Oct 15 07:55 doc /export2/prog/SunOS_x86_64/mpich-3.1.3_64_cc/share: drwxr-xr-x 3 root root 512 Oct 15 07:47 doc /export2/prog/SunOS_x86_64/mpich-3.1.3_64_gcc/share: drwxr-xr-x 3 root root 512 Oct 15 08:03 doc tyr mpich-3.1.3 178
Kind regards
Siegmar
Fixed in mpich/master:
http://git.mpich.org/mpich.git/commitdiff/866598b9d77a5c953ff5cc12cda2b78ae7...
33
Itâ?Tll be in the nightly snapshot tonight.
â?" Pavan
On Oct 14, 2014, at 10:31 AM, Balaji, Pavan <[email protected]> wrote:
Sorry, this is my bad. I tried to add a â?ofixâ? for an issue in
3.1.3 and clearly screwed up the common case.
http://git.mpich.org/mpich.git/commitdiff/354396f8362fd72c8f6750a479d86804bb...
aa
Iâ?Tll push a fix-for-this-fix into mpich/master shortly.
â?" Pavan
On Oct 14, 2014, at 9:49 AM, Siegmar Gross
I have no problem to get man pages when I install mpich-3.1.3. Could you send us log files of configure, make, and make install (i.e., c.txt, m.txt, and mi.txt as described in
http://www.mpich.org/static/downloads/3.1.3/mpich-3.1.3-installguide.pdf)?
Yes, I have attached the files for my Linux box and gcc-4.9.1.
I have the same problem for my three platforms (Solaris 10 Sparc, Solaris 10 x86_64, and openSUSE Linux 12.1), i.e., <install
dir>/share/man
isn't available, so that man pages couldn't be found. I didn't have this problem with mpich-3.1.2.
tyr prog 244 ls -l */mpich-3.1.3_64_*/share | grep -e : -e drwx Linux_x86_64/mpich-3.1.3_64_cc/share: drwxr-xr-x 3 root root 512 Oct 13 09:51 doc Linux_x86_64/mpich-3.1.3_64_gcc/share: drwxr-xr-x 3 root root 512 Oct 14 09:02 doc SunOS_sparc/mpich-3.1.3_64_cc/share: drwxr-xr-x 3 root root 512 Oct 13 10:15 doc SunOS_sparc/mpich-3.1.3_64_gcc/share: drwxr-xr-x 3 root root 512 Oct 14 09:32 doc SunOS_x86_64/mpich-3.1.3_64_cc/share: drwxr-xr-x 3 root root 512 Oct 13 10:06 doc SunOS_x86_64/mpich-3.1.3_64_gcc/share: drwxr-xr-x 3 root root 512 Oct 14 09:33 doc tyr prog 245
I used for example the following commands for Linux.
mkdir mpich-3.1.3-${SYSTEM_ENV}.${MACHINE_ENV}.64_gcc cd mpich-3.1.3-${SYSTEM_ENV}.${MACHINE_ENV}.64_gcc
../mpich-3.1.3/configure --prefix=/usr/local/mpich-3.1.3_64_gcc \ --libdir=/usr/local/mpich-3.1.3_64_gcc/lib64 \ --includedir=/usr/local/mpich-3.1.3_64_gcc/include64 \ CC="gcc" CXX="g++" F77="gfortran" FC="gfortran" \ CFLAGS="-m64" CXXFLAGS="-m64" FFLAGS="-m64" FCFLAGS="-m64" \ LDFLAGS="-m64" \ --enable-f77 --enable-fc --enable-cxx --enable-romio \ --enable-debuginfo --enable-smpcoll \ --enable-threads=runtime --with-thread-package=posix \ --enable-shared \ |& tee log.configure.$SYSTEM_ENV.$MACHINE_ENV.64_gcc
make |& tee log.make.$SYSTEM_ENV.$MACHINE_ENV.64_gcc rm -r /usr/local/mpich-3.1.3_64_gcc.old mv /usr/local/mpich-3.1.3_64_gcc /usr/local/mpich-3.1.3_64_gcc.old make install |& tee log.make-install.$SYSTEM_ENV.$MACHINE_ENV.64_gcc
Thank you very much for any help in advance.
Kind regards
Siegmar
Thanks, Sangmin
On Oct 14, 2014, at 6:12 AM, Siegmar Gross
<[email protected]<mailto:[email protected]
e>> wrote:
I installed mpich-3.1.3, but didn't get man pages, which were installed automatically for version mpich-3.1.2.
tyr mpich-3.1.3 226 ls -l /usr/local/mpich-3.1.2_64_gcc/share total 2 drwxr-xr-x 3 root root 512 Oct 14 09:28 doc drwxr-xr-x 4 root root 512 Oct 14 09:28 man tyr mpich-3.1.3 227 ls -l /usr/local/mpich-3.1.3_64_gcc/share total 1 drwxr-xr-x 3 root root 512 Oct 14 09:32 doc tyr mpich-3.1.3 228
tyr mpich-3.1.3-SunOS.sparc.64_gcc 232 grep MPI_Error_string log.* tyr mpich-3.1.3-SunOS.sparc.64_gcc 233 cd ../../mpich-3.1.2/mpich-3.1.2-SunOS.sparc.64_gcc tyr mpich-3.1.2-SunOS.sparc.64_gcc 234 grep MPI_Error_string log.* log.make-install.SunOS.sparc.64_gcc:/usr/local/bin/install -c -m 644 MPI_Error_string.3 /usr/local/mpich-3.1.2_64_gcc/share/man/man3/MPI_Error_string.3 tyr mpich-3.1.2-SunOS.sparc.64_gcc 235
Do I have to do something special for this version to install man pages?
Kind regards
Siegmar
_______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji âo?︠http://www.mcs.anl.gov/~balaji
participants (1)
Siegmar Gross
