Re: [mpich-discuss] [EXTERNAL] Re: Help with MPICH 4.2.0 and win_allocate_shared (or maybe infiniband?)
Ken, I think so. Given the traceback, my guess is it's dealing with this code from ESMF v8.6.0 (https://urldefense.us/v3/__https://github.com/esmf-org/esmf/blob/ec5f1866709... ) #if (MPI_VERSION >= 3) // set up communicator across single-system-images SSIs MPI_Comm_split_type(mpi_c, MPI_COMM_TYPE_SHARED, 0, MPI_INFO_NULL, &mpi_c_ssi); // set up communicator across root pets of each SSI int color; MPI_Comm_rank(mpi_c_ssi, &color); if (color>0) color = MPI_UNDEFINED; // only root PETs on each SSI MPI_Comm_split(mpi_c, color, 0, &mpi_c_ssi_roots); #endif Indeed, if it's coming from ESMF, that is the *only* MPI_Comm_split_type in the whole code! We also call MPI_Comm_split_type in the overall code (MAPL) and it also only uses that: https://urldefense.us/v3/__https://github.com/search?q=repo*3AGEOS-ESM*2FMAP... -- Matt Thompson, SSAI, Ld Scientific Prog/Analyst/Super NASA GSFC, Global Modeling and Assimilation Office Code 610.1, 8800 Greenbelt Rd, Greenbelt, MD 20771 Phone: 301-614-6712 Fax: 301-614-6246 https://urldefense.us/v3/__http://science.gsfc.nasa.gov/sed/bio/matthew.thom... From: Raffenetti, Ken <[email protected]> Date: Tuesday, March 26, 2024 at 10:55 AM To: [email protected] <[email protected]> Cc: Thompson, Matt (GSFC-610.1)[SCIENCE SYSTEMS AND APPLICATIONS INC] <[email protected]> Subject: [EXTERNAL] Re: [mpich-discuss] Help with MPICH 4.2.0 and win_allocate_shared (or maybe infiniband?) It looks like the crash is happening after shared memory window creation fails. The failure path is getting tripped up removing the window id from the global hash, since it was never added. We will address this in the code so users get a better error message after the failure. Can you confirm that the input communicator to the window creation function is one created with MPI_Comm_split_type(…,MPI_COMM_TYPE_SHARED,…)? Thanks, Ken From: "Thompson, Matt (GSFC-610.1)[SCIENCE SYSTEMS AND APPLICATIONS INC] via discuss" <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Tuesday, March 26, 2024 at 9:20 AM To: "[email protected]" <[email protected]> Cc: "Thompson, Matt (GSFC-610.1)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <[email protected]> Subject: [mpich-discuss] Help with MPICH 4.2.0 and win_allocate_shared (or maybe infiniband?) All, I've been trying to get a code of mine working with MPICH 4. 2. 0. I can build MPICH just fine and then build our base libraries and then model and all compiles fine. Hello world runs fine on multiple nodes as well. But when I finally try ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd All, I've been trying to get a code of mine working with MPICH 4.2.0. I can build MPICH just fine and then build our base libraries and then model and all compiles fine. Hello world runs fine on multiple nodes as well. But when I finally try and run our complex model: Assertion failed in file ../src/mpid/ch4/src/ch4_impl.h at line 838: map_entry != NULL /discover/swdev/gmao_SIteam/MPI/mpich/4.2.0-SLES15/ifort-2021.11.0/lib/libmpi.so.12(+0x37d211) [0x14bf4f62c211] /discover/swdev/gmao_SIteam/MPI/mpich/4.2.0-SLES15/ifort-2021.11.0/lib/libmpi.so.12(PMPI_Win_allocate_shared+0x3ba) [0x14bf4f3e452a] /discover/swdev/gmao_SIteam/Baselibs/ESMA-Baselibs-7.20.0/x86_64-pc-linux-gnu/ifort_2021.11.0-mpich_4.2.0-SLES15/Linux/lib/libesmf.so(_ZN5ESMCI3VMK14ssishmAllocateERSt6vectorImSaImEEPNS0_9memhandleEb+0x18b) [0x14bf6e91481b] /discover/swdev/gmao_SIteam/Baselibs/ESMA-Baselibs-7.20.0/x86_64-pc-linux-gnu/ifort_2021.11.0-mpich_4.2.0-SLES15/Linux/lib/libesmf.so(_ZN5ESMCI5Array6createEPNS_9ArraySpecEPNS_8DistGridEPNS_10InterArrayIiEES7_S7_S7_S7_S7_S7_P14ESMC_IndexFlagP13ESMC_Pin_FlagS7_S7_S7_PiPNS_2VME+0x2707) [0x14bf6e44a267] What I'm mainly wondering is if anyone has any experience with an error like this? My guess (at the moment) is that I built things wrong for an Infiniband cluster maybe? I'm using Intel Fortran Classic 2021.11.0 with GCC 11.4.0 as a backing C compiler and I built as: mkdir build-ifort-2021.11.0 && cd build-ifort-2021.11.0 ../configure CC=icx CXX=icpx FC=ifort \ --with-ucx=embedded --with-hwloc=embedded --with-libfabric=embedded --with-yaksa=embedded \ --prefix=/discover/swdev/gmao_SIteam/MPI/mpich/4.2.0-SLES15/ifort-2021.11.0 |& tee configure.ifort-2021.11.0.log All those "embedded" flags are mainly because with Open MPI on this system, I have to do something similar with its configure step: --with-hwloc=internal --with-libevent=internal --with-pmix=internal so I figured I should do the same with MPICH> Now, at the end of the configure step I did see: ***************************************************** *** *** device : ch4:ofi (embedded libfabric) *** shm feature : auto *** gpu support : disabled *** MPICH is configured with device ch4:ofi, which should work for TCP networks and any high-bandwidth interconnect supported by libfabric. MPICH can also be configured with "--with-device=ch4:ucx", which should work for TCP networks and any high-bandwidth interconnect supported by the UCX library. In addition, the legacy device ch3 (--with-device=ch3) is also available. ***************************************************** And I did try the `--with-device=ch4:ucx` but that didn't seem to help. And the system I am on is an Infiniband network, so I imagine ofi should work. Note that this code works fine with Intel MPI and Open MPI (which are our "main" MPI stacks), but some of our external users are asking about MPICH support. Matt -- Matt Thompson, SSAI, Ld Scientific Prog/Analyst/Super NASA GSFC, Global Modeling and Assimilation Office Code 610.1, 8800 Greenbelt Rd, Greenbelt, MD 20771 Phone: 301-614-6712 Fax: 301-614-6246 https://urldefense.us/v3/__http://science.gsfc.nasa.gov/sed/bio/matthew.thom... <https://urldefense.us/v3/__http:/science.gsfc.nasa.gov/sed/bio/matthew.thompson__;!!G_uCfscf7eWS!Y6jfxrSalGUYiT8VqK_4OwkY3bftJ-gwM5C6AHyrxvP2BZZvQlHGBeYZnUWmkPQJN7-mWjRBpQg60pHQJKXDetYFzss$>
participants (1)
