MPICH 3.4.1 and macOS 11.2 (aka Big Sur)
Hello, First post to the discussion board. I made the mistake of upgrading to macOS 11.2 (aka Big Sur). I was able to build MPICH 3.4.1 successfully and integrate it with an application. However, when I ran, MPICH crashed. Here is the initial output: Abort(1) on node 0: Internal error 0 libpmpi.12.dylib 0x00000001068c2159 MPL_backtrace_show + 57 1 libpmpi.12.dylib 0x000000010684e874 MPIR_Assert_fail + 36 2 libpmpi.12.dylib 0x0000000106897bc8 MPIDI_OFI_mpi_init_hook + 4472 3 libpmpi.12.dylib 0x00000001068790d3 MPID_Init + 3091 4 libpmpi.12.dylib 0x00000001066ae70b MPIR_Init_thread + 219 5 libmpi.12.dylib 0x00000001064bb897 MPI_Init + 279 I have not yet dug into the issue any further. Before doing so I wanted to first check to see if others have successfully built and run via macOS 11.2. If so I would appreciate any pointers. If it is known that it will not yet work, that would be good information as well so not to spend anytime digging. I should note that on another machine, I was wiser and upgraded to macOS 10.5.7 (aka Catalina) and built and ran with 3.3.1 that worked fine running in parallel. Cheers, Allen Allen Sanderson SCI Institute University of Utah
participants (1)
Allen Sanderson
