Re: [mpich-discuss] Do I need to run "mpd" every time before I execute "mpiexec"?
You should not have to specify hydra with the 3.0.4 release. It is the default. Can you send your config.log so we know what went wrong? ----- Original Message -----
From: "Seungbum Koo" <[email protected]> To: "Jeff Hammond" <[email protected]>, [email protected] Cc: "MPICH" <[email protected]> Sent: Thursday, September 5, 2013 6:59:12 AM Subject: Re: [mpich-discuss] Do I need to run "mpd" every time before I execute "mpiexec"?
Wow. Thank you for the fast replies. You guys hardly sleep.
PROBLEM SOLVED. It works now.
Nicolás/ No. that can't be. It is my personal computer and I haven't installed MPICH so far. Jeff/ I saw that FAQ but didn't try --with-pm=hydra.
I first didn't configure MPICH with any process manager since hydra is set to default according to the installation guide. I reconfigured "--with-pm=hydra" and reinstalled. Now it is working.
Once again, thank you for your interest and help.
Seungbum
On Wed, Sep 4, 2013 at 11:14 PM, Jeff Hammond < [email protected] > wrote:
http://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_I_don.27...
On Wed, Sep 4, 2013 at 11:02 PM, Nicolas Rosner < [email protected] > wrote:
Hi Seungbum,
do I need to run "mpd" every time before I run "mpiexec"?
No. You shouldn't need to run mpd at all.
From the FAQ: "The mpd process manager has many problems, as well as an annoying mpdboot step that is fragile and difficult to use correctly. The mpd process manager is deprecated at this point ..."
Perhaps when you typed "mpiexec", you were not really running the mpiexec binary that you had just built, but rather some other (really old) version that was already lying around on your system?
I'd suggest: running "which mpiexec" and "mpiexec --version" checking your $PATH specifying an absolute pathname to the new mpiexec binary instead of just "mpiexec"
Hope this helps, Nicolás _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected]
participants (1)
Ken Raffenetti
