Re: [mpich-discuss] turning off MPI abort messages
I have already implemented the CVAR logic to suppress the output in MPI_Abort so the necessary convincing is only as to whether or not MPICH folks accepts this patch. I'm not sure whether I will bother to do anything to Hydra. Seems like one could wrap the binary in a "nofail" script (we use these on BG a lot because of how the control system responds to error codes) to keep Hydra from complaining. However, this is shell magic and clearly I don't know anything about shell because I think nonzero error codes in MPI programs imply that ls crashes when looking for missing files. Jeff On Fri, Feb 21, 2014 at 1:28 PM, Jim Dinan <[email protected]> wrote:
Barry,
Do you need a portable solution that works across different MPI implementations, or does a solution for making just MPICH silent address your need? If the latter, you could probably convince someone on the MPICH team to add an environment variable for MPICH and a command-line "quiet" flag for hydra/mpiexec.
~Jim.
On Fri, Feb 21, 2014 at 2:13 PM, Barry Smith <[email protected]> wrote:
Understood. But I would like to eliminate both sets of error messages and still provide a useful “return code”. Perhaps compile time options to the library?
Barry
On Feb 21, 2014, at 12:40 PM, Jim Dinan <[email protected]> wrote:
A little more detail -- you're actually getting messages from two sources: (1) the MPICH library ("application called MPI_Abort...") and (2) the job launcher ("BAD TERMINATION..."). You can eliminate the messages from the job launcher by providing an error code of 0 in MPI_Abort.
~Jim.
On Fri, Feb 21, 2014 at 1:19 PM, Jeff Hammond <[email protected]> wrote:
Just configure MPICH such that snprintf isn't discovered by configure and you won't see these messages.
The other solution is to fix PETSc so that people can't crash it so easily ;-)
Here we go again. It is not CRASHING; it has detected an error conditioning and trying to appropriately and cleanly terminate. The reason it needs to use MPI_Abort() is that often detecting error conditions is not a uniformly collective thing.
Printing a suitable error message and ending is not crashing. But with all the badly formatted “error messages” printed by MPICH I can not control at the end it looks like it is crashing.
You're returning a non-zero exit code, which I consider crashing. I apologize if this definition disagrees with yours. If this is just gentle cleanup, why not exit with code=0 as Jim suggested already?
Jeff
On Thu, Feb 20, 2014 at 3:19 PM, Jim Dinan <[email protected]> wrote:
If you can find a way to call MPI_Finalize instead, you will portably eliminate these messages.
A lesser solution would be to provide an error code of 0 (or MPI_SUCCESS) to MPI_Abort, e.g. MPI_Comm_abort(MPI_COMM_WORLD, MPI_SUCCESS). This would eliminate the error message that you are getting from the job launcher. MPICH could be modified to be quiet about the abort when the application aborts with an error code of MPI_SUCCESS.
~Jim.
On Thu, Feb 20, 2014 at 12:33 PM, Barry Smith <[email protected]> wrote:
Is there any way to turn off MPICH (and others) printing messages about MPI_Abort? We have already prepared and presented useful error messages to the user about the situation and would like to avoid having these additional messages printed (that often make the situation look worse than it is)
Thanks
Barry
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0 [cli_0]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
==================================================================mailto:[email protected]================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 56 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
