Re: [mpich-discuss] Issue with MPICH + mpi4py on Ubuntu 24.04
This is a known ubuntu package issue -https://urldefense.us/v3/__https://bugs.launchpad.net/ubuntu/*source/mpich/*... Hui ________________________________ From: Jørgen Dokken via discuss <[email protected]> Sent: Monday, September 16, 2024 2:06 AM To: [email protected] <[email protected]> Cc: Jørgen Dokken <[email protected]> Subject: [mpich-discuss] Issue with MPICH + mpi4py on Ubuntu 24.04 When trying to install MPICH from the apt repository on Ubuntu 24. 04 and then installing mpi4py with pip, I get a non-functional installation of mpi4py. It does not happen if I use openmpi, or downgrade to Ubuntu 22. 04. It has been tested with ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd When trying to install MPICH from the apt repository on Ubuntu 24.04 and then installing mpi4py with pip, I get a non-functional installation of mpi4py. It does not happen if I use openmpi, or downgrade to Ubuntu 22.04. It has been tested with the same MPICH on other systems (See: https://urldefense.us/v3/__https://github.com/mpi4py/mpi4py/issues/547__;!!G... <https://urldefense.us/v3/__https://github.com/mpi4py/mpi4py/issues/547__;!!G_uCfscf7eWS!cPoueuWR7fxw1e0Sea_FpPwE69LSB-4AL5z_w7BTkhgE477ScU4TJA4tOTBUI_OpT980NxbAga-iHw$>) for where it has been tested, leading one to believe that something is wrong with the ubuntu build. Minimal reproducible dockerfile: ``` FROM ubuntu:24.04 ARG MPI="mpich" ENV OPENBLAS_NUM_THREADS=1 \ OPENBLAS_VERBOSE=0 ENV DEB_PYTHON_INSTALL_LAYOUT=deb_system ENV DEBIAN_FRONTEND=noninteractive WORKDIR /tmp RUN apt-get -qq update && \ apt-get -yq upgrade && \ apt-get -y install \ lib${MPI}-dev \ python3-dev \ python3-pip \ python3-setuptools \ python3-venv && \ apt-get clean && \ rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ENV VIRTUAL_ENV=/test-env ENV PATH=/${VIRTUAL_ENV}/bin:$PATH RUN python3 -m venv ${VIRTUAL_ENV} # Install Python packages (via pip) RUN python3 -m pip install --no-cache-dir mpi4py -v ENV OMPI_ALLOW_RUN_AS_ROOT=1 \ OMPI_ALLOW_RUN_AS_ROOT_CONFIRM=1 CMD ["mpiexec", "-v", "--np", "2", "python3", "-c", "from mpi4py import MPI; print(f'{MPI.COMM_WORLD.rank}/{MPI.COMM_WORLD.size}')"] ``` with the output ``` host: 6a2e05040a65 [mpiexec@6a2e05040a65] Timeout set to -1 (-1 means infinite) ================================================================================================== mpiexec options: ---------------- Base path: /usr/bin/ Launcher: (null) Debug level: 1 Enable X: -1 Global environment: ------------------- PATH=//test-env/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin HOSTNAME=6a2e05040a65 TERM=xterm OPENBLAS_NUM_THREADS=1 OPENBLAS_VERBOSE=0 DEB_PYTHON_INSTALL_LAYOUT=deb_system DEBIAN_FRONTEND=noninteractive VIRTUAL_ENV=/test-env OMPI_ALLOW_RUN_AS_ROOT=1 OMPI_ALLOW_RUN_AS_ROOT_CONFIRM=1 HOME=/root Hydra internal environment: --------------------------- GFORTRAN_UNBUFFERED_PRECONNECTED=y Proxy information: ********************* [1] proxy: 6a2e05040a65 (1 cores) Exec list: python3 (2 processes); ================================================================================================== Proxy launch args: /usr/bin/hydra_pmi_proxy --control-port 6a2e05040a65:36819 --debug --rmk user --launcher ssh --demux poll --pgid 0 --retries 10 --usize -2 --pmi-port 0 --gpus-per-proc -2 --gpu-subdevs-per-proc -2 --proxy-id Arguments being passed to proxy 0: --version 4.2.0 --iface-ip-env-name MPIR_CVAR_CH3_INTERFACE_HOSTNAME --hostname 6a2e05040a65 --global-core-map 0,1,1 --pmi-id-map 0,0 --global-process-count 2 --auto-cleanup 1 --pmi-kvsname kvs_1_0_1589598326_6a2e05040a65 --pmi-process-mapping (vector,(0,1,2)) --global-inherited-env 11 'PATH=//test-env/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin' 'HOSTNAME=6a2e05040a65' 'TERM=xterm' 'OPENBLAS_NUM_THREADS=1' 'OPENBLAS_VERBOSE=0' 'DEB_PYTHON_INSTALL_LAYOUT=deb_system' 'DEBIAN_FRONTEND=noninteractive' 'VIRTUAL_ENV=/test-env' 'OMPI_ALLOW_RUN_AS_ROOT=1' 'OMPI_ALLOW_RUN_AS_ROOT_CONFIRM=1' 'HOME=/root' --global-user-env 0 --global-system-env 1 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 2 --exec-local-env 0 --exec-wdir /tmp --exec-args 3 python3 -c from mpi4py import MPI; print(f'{MPI.COMM_WORLD.rank}/{MPI.COMM_WORLD.size}'); [mpiexec@6a2e05040a65] Launch arguments: /usr/bin/hydra_pmi_proxy --control-port 6a2e05040a65:36819 --debug --rmk user --launcher ssh --demux poll --pgid 0 --retries 10 --usize -2 --pmi-port 0 --gpus-per-proc -2 --gpu-subdevs-per-proc -2 --proxy-id 0 [proxy:0@6a2e05040a65] Sending upstream hdr.cmd = CMD_PID_LIST [proxy:0@6a2e05040a65] Sending upstream hdr.cmd = CMD_STDOUT [proxy:0@6a2e05040a65] Sending upstream hdr.cmd = CMD_STDOUT 0/1 0/1 [proxy:0@6a2e05040a65] Sending upstream hdr.cmd = CMD_EXIT_STATUS ``` Best, Jørgen -- Jørgen S. Dokken, PhD Senior Research Engineer Simula Research Laboratory +47 45286467
participants (1)
Zhou, Hui
