Re: [mpich-discuss] Problem with RMA && MPI_Type_vector when stride value is relatively large
Also, you should use the latest stable release MPICH-3.1.3 at http://www.mpich.org/downloads/ --Junchao Zhang On Thu, Oct 16, 2014 at 8:40 AM, Seo, Sangmin <[email protected]> wrote:
Hi Victor,
Your code was not attached. Can you send it again?
Thanks, Sangmin
On Oct 16, 2014, at 6:34 AM, Victor Vysotskiy < [email protected]> wrote:
I am straggling with a simple MPI program when a vector derived datatype is used as origin/remote datatypes in the MPI_Put RMA operation. The underlying idea is quite simple: a contiguous piece of memory is interpreted as a 2D array and only its certain slice is going to be updated via MPI_Put. To this end, I am using a MPI_Type_vector call. Everything works fine when the stride value <= 24000, regardless count and blocklength. However, if stride is greater than 24000 then program simply hangs. The source code is attached and you can simply verify the issue by compiling and running it with the following parameters:
mpicc mpi_tvec_rma.c
mpirun -np 2 ./a.out 10000 2000
Ok
mpirun -np 2 ./a.out 20000 2000
Ok
mpirun -np 2 ./a.out 30000 2000
Hangs
Is there any internal/known limits to the size of MPI_TYPE_VECTOR datatypes?
So, I am really puzzled what is happening here and any help will be greatly appreciated!
With best regards,
Victor.
P.S. The attached code is perfectly runs with the OpenMPI v1.8.2.
P.P.S. Below are given some details about hardware and software setups used:
MPICH2 Version: 1.5
MPICH2 Release date: Mon Oct 8 14:00:48 CDT 2012
MPICH2 Device: ch3:nemesis
MPICH2 configure: --prefix=/opt/mpi/mpich2/ --disable-weak-symbols
MPICH2 CC: gcc -O2
MPICH2 CXX: c++ -O2
MPICH2 F77: gfortran -O2
MPICH2 FC: gfortran -O2
GCC version 4.7.3
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Junchao Zhang
