Re: [mpich-discuss] Very long configuration time
Please double check that you are actually using a local disk (e.g. "df"). If that's the case, you're likely facing a slow disk access. I'd say that there's nothing you can be doing wrong to increase the configuration time. You could disable parts of MPICH you won't use, such as --disable-cxx --disable-fortran --disable-romio, but that will help only for the compilation stage. Antonio On 05/21/2014 01:42 PM, Yida Wang wrote:
It is still running, so definitely more than a few minutes. Any other thing that I did wrong?
On Wed, May 21, 2014 at 2:32 PM, "Antonio J. Pe�a" <[email protected] <mailto:[email protected]>> wrote:
On a decent system, I'd expect it to finish in a few minutes at most.
Antonio
On 05/21/2014 01:30 PM, Yida Wang wrote:
Thanks for your reply, Antonio! Yes, I was using NFS before, am trying on local disk now. BTW, what will a normal time be?
On Wed, May 21, 2014 at 2:20 PM, "Antonio J. Pe�a" <[email protected] <mailto:[email protected]>> wrote:
Hi YW,
Although 8h looks like a very long time to me, it's likely due to a network filesystem. If that's the case, configuring MPICH in a local filesystem (e.g. /temp, /tmp, /scratch) should go back to normal times.
Antonio
On 05/21/2014 01:17 PM, Yida Wang wrote:
Hi Guys,
I would like to try out the feature of talking to Intel-MIC in MPICH2. Therefore I downloaded mpich-3.1 and configured it as
"./configure --host=x86_64-k1om-linux CC=icc CXX=icpc F77=ifort FC=ifort CFLAGS=-mmic CXXFLAGS=-mmic FFLAGS=-mmic FCFLAGS=-mmic LDFLAGS=-mmic"
However, it took a very long time (i.e. 8 hours) for me to finish the configuration. Is it normal? Notice that my system doesn't have Infiniband but 10GigE connection. However, I don't think this would affect the configuration time.
Thanks, YW
_______________________________________________ discuss mailing [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Pe�a Postdoctoral Appointee Mathematics and Computer Science Division Argonne National Laboratory 9700 South Cass Avenue, Bldg. 240, Of. 3148 Argonne, IL 60439-4847 [email protected] <mailto:[email protected]> www.mcs.anl.gov/~apenya <http://www.mcs.anl.gov/%7Eapenya>
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Pe�a Postdoctoral Appointee Mathematics and Computer Science Division Argonne National Laboratory 9700 South Cass Avenue, Bldg. 240, Of. 3148 Argonne, IL 60439-4847 [email protected] www.mcs.anl.gov/~apenya
participants (1)
"Antonio J. Peña"
