Re: [mpich-discuss] Increasing MPI ranks
I was unaware of this issue with mpi4py, but I can reproduce it as well. I will contact the mpi4py developers. Thank you again for your help! On Wed, Mar 12, 2014 at 10:09 AM, Lu, Huiwei <[email protected]> wrote:
Hi, Jeffrey,
The example in mpi4py manual can not run correctly with more than 16 processes. So I have a reason to believe mpi4py library is not calling MPI correctly. It would be more appropriate to ask mpi4py developers to support their manual example to run more than 16 processes first.
-- Huiwei
On Mar 11, 2014, at 8:40 PM, Jeffrey Larson <[email protected]> wrote:
I was using the example from the mpi4py manual: http://mpi4py.scipy.org/docs/mpi4py.pdf (See the lines directly below "Worker (or child, or server) side:" in Section 4.3: Dynamic Process Management)
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeffrey Larson
