Re: [mpich-discuss] Should MPI_Abort() call exit or _exit?
Yeah, I think `PETSc` should not really do that. Depend on the applications and process manager, calling `_exit` in the signal handler maybe clean enough – especially when the SIGTERM is sent by the process manager so it doesn’t need the process tell it back that “I’m aborting”. -- Hui Zhou From: John Peterson <[email protected]> Date: Tuesday, April 21, 2020 at 2:06 PM To: "Zhou, Hui" <[email protected]> Cc: "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] Should MPI_Abort() call exit or _exit? Hi, Thanks for your reply. Since in this case it's PETSc's PetscSignalHandlerDefault signal handler which actually calls MPI_Abort(), are you saying they should not do that? Any suggestion for what they should do instead? It seems that there is then no clean way of terminating an MPI process that receives SIGTERM? -- John On Tue, Apr 21, 2020 at 1:18 PM Zhou, Hui <[email protected]<mailto:[email protected]>> wrote: Let’s make it clear – inside a signal handler, one is not allowed to call any interrupt unsafe functions, that includes all MPI functions including `MPI_Abort`, which means `MPL_exit` should never be called inside a signal handler. Back to the question, since `MPL_exit` is not inside a signal handler, it is allowed to call `exit`. I don’t think it is possible to do any real clean up inside a signal handler. The best a signal handler can do is to flip some atomic flags, the your applications should have checkpoints check those flags and do your graceful exit if necessary. -- Hui Zhou From: John Peterson via discuss <[email protected]<mailto:[email protected]>> Reply-To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> Date: Tuesday, April 21, 2020 at 1:06 PM To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> Cc: John Peterson <[email protected]<mailto:[email protected]>> Subject: [mpich-discuss] Should MPI_Abort() call exit or _exit? Hi, I have what is a fairly convoluted question involving several different libraries, so I'll try to make it as succinct as possible. The issue is that we have an MPI job that is canceled by slurm's "scancel", but instead of exiting cleanly, the job (sometimes) hangs. I think we've tracked it down to the job being canceled while in the middle of a call to "free" and then "free" subsequently being called again from a function called by the signal handler, which leads to the deadlock. The general rule seems to be that only "asynchronous-safe" functions (abort(), _Exit(), etc.) are allowed to be called in signal handlers [0]. In our specific case, the stack trace of one of the hung jobs is: #0 __lll_lock_wait_private () at ../sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:95 #1 0x00007ff175223114 in _int_free (have_lock=0, p=0x55cd9120f2a0, av=0x7ff175576c40 <main_arena>) at malloc.c:4266 #2 __GI___libc_free (mem=0x55cd9120f2b0) at malloc.c:3124 #3 0x00007ff1714938aa in H5MM_xfree () #4 0x00007ff17147e5da in H5L_term_package () #5 0x00007ff17133a766 in H5_term_library () #6 0x00007ff1751ce041 in __run_exit_handlers (status=59, listp=0x7ff175576718 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true, run_dtors=run_dtors@entry=true) at exit.c:108 #7 0x00007ff1751ce13a in __GI_exit (status=<optimized out>) at exit.c:139 #8 0x00007ff176f3c809 in MPL_exit () from /usr/lib/x86_64-linux-gnu/libmpich.so.0 #9 0x00007ff176eefd4c in ?? () from /usr/lib/x86_64-linux-gnu/libmpich.so.0 #10 0x00007ff176e3ea59 in PMPI_Abort () from /usr/lib/x86_64-linux-gnu/libmpich.so.0 #11 0x00007ff177635531 in PetscSignalHandlerDefault () #12 0x00007ff177635270 in PetscSignalHandler_Private () #13 <signal handler called> #14 0x00007ff175222c6f in _int_free (have_lock=0, p=0x55cd9345e360, av=0x7ff175576c40 <main_arena>) at malloc.c:4280 #15 __GI___libc_free (mem=0x55cd9345e370) at malloc.c:3124 To summarize this: 1.) We are in a call to "free" 2.) The process receives a sigterm/sigkill signal, which petsc handles 3.) petsc calls mpich's abort function 4.) mpich calls "exit", which causes the "atexit" functions to run 5.) HDF5 registers an "atexit" function which also calls "free" 6.) Deadlock This could definitely be seen as an HDF5 issue: I'm not sure of the wisdom of registering "atexit" functions which free memory -- the program is exiting after all. But, I also wanted to confirm whether calling exit() from MPL_exit() is a deliberate choice, or if it could perhaps be changed to _exit, which I think would avoid this particular problem. Thanks, John [0]: https://wiki.sei.cmu.edu/confluence/display/c/SIG30-C.+Call+only+asynchronou...
participants (1)
Zhou, Hui
