Re: [mpich-discuss] Mpich won't compile with gcc-5
Yes this was the poroblem. Now its compiling. Thank you Jan On 18.02.2015 12:18, Balaji, Pavan wrote:
Did you check if gfortran-5 works for simple Fortran programs? It looks like it doesn't.
configure:38446: ./conftest ./conftest: error while loading shared libraries: libquadmath.so.0: cannot open shared object file: No such file or directory configure:38446: $? = 127 configure: program exited with status 127 configure: failed program was: | | | program main | real a(2) | integer irc, cisize | irc = cisize(a(1),a(2)) | end
-- Pavan
On Feb 18, 2015, at 4:56 AM, Jan Wittke <[email protected]> wrote:
Yes,
here.
Thank you Jan
On 18.02.2015 11:52, Balaji, Pavan wrote:
Can you send the config.log file?
-- Pavan
On Feb 18, 2015, at 4:28 AM, Jan Wittke <[email protected]> wrote:
Yes,
I only want to use gfortran-5.
Regards, Jan
On 18.02.2015 11:26, Balaji, Pavan wrote:
Are you using gfortran-5 as well? That seems to be giving an issue. If you don't need fortran, you can disable it by passing --disable-fortran to configure.
-- Pavan
On Feb 18, 2015, at 4:14 AM, Jan Wittke <[email protected]> wrote:
after installing gcc-5-20150208 from source with
/opt/gcc-5-20150208/configure --program-suffix=-5 --prefix=/usr/local --enable-languages=c,c++,fortran --disable-multilib
I am not able to run the mpich ./configure script properly. Doing:
CC=/usr/local/bin/gcc-5 FC=/usr/local/bin/gfortran-5 ./configure --enable-threads
in the mpich-3.2a2 directory I got the error:
configure: error: Unable to configure with Fortran support because configure could not determine the size of a Fortran INTEGER. Consider setting CROSS_F77_SIZEOF_INTEGER to the length in bytes of a Fortran INTEGER
Is there any fix around ?
Thank you, Jan
<config.log>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
-- Jan Wittke Geophysicist (M.Sc.) Institute of Geophysics and Meteorology University of Cologne Email: [email protected] Homepage: www.geomet.uni-koeln.de Tel.: +49 (0)221 470 6132 / Room 310 _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jan Wittke
