Re: [mpich-discuss] error spawning processes in mpich-3.2rc1
Hi Min,
It seems you already enabled the most detailed error outputs. We could not think out any clue for now. If you can give us access to your machine, we are glad to help you debug on it.
Can you send me your email address because I don't want to send login data to this list. Kind regards Siegmar
Min
On 10/8/15 12:02 AM, Siegmar Gross wrote:
Hi Min,
thank you very much for your answer.
We cannot reproduce this error on our test machines (Solaris i386, Ubuntu x86_64) by using your programs. And unfortunately we do not have Solaris Sparc machine thus could not verify it.
The programs work fine on my Solaris x86_64 and Linux machines as well. I only have a problem on Solaris Sparc.
Sometime, it can happen that you need to add "./" in front of the program path, could you try it ?
For example, in spawn_master.c MPI: A Message-Passing Interface Standard
#define SLAVE_PROG "./spawn_slave"
No, it wil not work, because the programs are stored in a different directory ($HOME/{SunOS, Linux}/{sparc, x86_64}/bin) which is part of PATH (as well as ".").
Can I do anything to track the source of the error?
Kind regards
Siegmar
Min
On 10/7/15 5:03 AM, Siegmar Gross wrote:
today I've built mpich-3.2rc1 on my machines (Solaris 10 Sparc, Solaris 10 x86_64, and openSUSE Linux 12.1 x86_64) with gcc-5.1.0 and Sun C 5.13. I still get the following errors on my Sparc machine which I'd already reported September 8th. "mpiexec" is aliased to 'mpiexec -genvnone'. It still doesn't matter if I use my cc- or gcc-version of MPICH.
tyr spawn 119 mpichversion MPICH Version: 3.2rc1 MPICH Release date: Wed Oct 7 00:00:33 CDT 2015 MPICH Device: ch3:nemesis MPICH configure: --prefix=/usr/local/mpich-3.2_64_cc --libdir=/usr/local/mpich-3.2_64_cc/lib64 --includedir=/usr/local/mpich-3.2_64_cc/include64 CC=cc CXX=CC F77=f77 FC=f95 CFLAGS=-m64 CXXFLAGS=-m64 FFLAGS=-m64 FCFLAGS=-m64 LDFLAGS=-m64 -L/usr/lib/sparcv9 -R/usr/lib/sparcv9 --enable-fortran=yes --enable-cxx --enable-romio --enable-debuginfo --enable-smpcoll --enable-threads=multiple --with-thread-package=posix --enable-shared MPICH CC: cc -m64 -O2 MPICH CXX: CC -m64 -O2 MPICH F77: f77 -m64 MPICH FC: f95 -m64 -O2 tyr spawn 120
tyr spawn 111 mpiexec -np 1 spawn_master
Parent process 0 running on tyr.informatik.hs-fulda.de I create 4 slave processes
Fatal error in MPI_Comm_spawn: Unknown error class, error stack: MPI_Comm_spawn(144)...........: MPI_Comm_spawn(cmd="spawn_slave", argv=0, maxprocs=4, MPI_INFO_NULL, root=0, MPI_COMM_WORLD, intercomm=ffffffff7fffde50, errors=0) failed MPIDI_Comm_spawn_multiple(274): MPID_Comm_accept(153).........: MPIDI_Comm_accept(1057).......: MPIR_Bcast_intra(1287)........: MPIR_Bcast_binomial(310)......: Failure during collective
tyr spawn 112 mpiexec -np 1 spawn_multiple_master
Parent process 0 running on tyr.informatik.hs-fulda.de I create 3 slave processes.
Fatal error in MPI_Comm_spawn_multiple: Unknown error class, error stack: MPI_Comm_spawn_multiple(162)..: MPI_Comm_spawn_multiple(count=2, cmds=ffffffff7fffde08, argvs=ffffffff7fffddf8, maxprocs=ffffffff7fffddf0, infos=ffffffff7fffdde8, root=0, MPI_COMM_WORLD, intercomm=ffffffff7fffdde4, errors=0) failed MPIDI_Comm_spawn_multiple(274): MPID_Comm_accept(153).........: MPIDI_Comm_accept(1057).......: MPIR_Bcast_intra(1287)........: MPIR_Bcast_binomial(310)......: Failure during collective
tyr spawn 113 mpiexec -np 1 spawn_intra_comm Parent process 0: I create 2 slave processes Fatal error in MPI_Comm_spawn: Unknown error class, error stack: MPI_Comm_spawn(144)...........: MPI_Comm_spawn(cmd="spawn_intra_comm", argv=0, maxprocs=2, MPI_INFO_NULL, root=0, MPI_COMM_WORLD, intercomm=ffffffff7fffded4, errors=0) failed MPIDI_Comm_spawn_multiple(274): MPID_Comm_accept(153).........: MPIDI_Comm_accept(1057).......: MPIR_Bcast_intra(1287)........: MPIR_Bcast_binomial(310)......: Failure during collective tyr spawn 114
I would be grateful if somebody can fix the problem. Thank you very much for any help in advance. I've attached my programs. Please let me know if you need anything else.
Kind regards
Siegmar
_______________________________________________ discuss mailing [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Siegmar Gross
