Re: [mpich-discuss] MPICH error on CentOS
I have created the file mpd.hosts in /etc folder in the root , but still it shows the same error ... /usr/bin/mpdroot: open failed for root's mpd conf filempiexec_localhost.localdomain (__init__ 1208): forked process failed; status=255 On Thu, Nov 7, 2013 at 8:45 AM, Ricardo Román Brenes < [email protected]> wrote:
You need to create a mpd.hosts in /etc if you want to run mpd as root On Nov 6, 2013 5:41 PM, "bharat gupta" <[email protected]> wrote:
I am getting the following error while using the command -
[root@localhost INGT]# mpirun -np 24 mdrun_mpi -v -deffnm npt
Error -
I complied gromacs using - ./configure --enable-shared --enable-mpi. I have installed the mpich package , this is what I get when I check for mpirun and mpiexec -
[root@localhost /]# which mpirun /usr/bin/mpirun [root@localhost /]# which mpiexec /usr/bin/mpiexec
What could be the problem here ??
Thanks -------- Bharat
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Bharat Ph.D. Candidate Biomolecular Engineering Laboratory Pusan National University South Korea Mobile no. - 010-5818-3680
participants (1)
bharat gupta
