Re: [mpich-discuss] [EXTERNAL] Re: error building cuda from yaksa
That was what I thought also. Unfortunately this doesn't work. The purpose of setting $LIBTOOL_VERSION is to embed the version in the .lo file $LO_FILEPATH that is created in the next statement. Although the version is placed in something that appears to be a comment, it is required later by something else called 'libtool', and it is considered to be an error if the version is missing: libtool: error: 'src/backend/cuda/pup/yaksuri_cudai_pup__Bool.lo' is not a valid libtool object The file contains the line # Generated by This is a rather cryptic error message, but it goes away if the libtool invocation on line 44 is changed to './libtool'. That is marginally OK if cudalt.sh is only invoked in that directory (which seems to be true just now) but it's not a permanent solution IMHO. I have attached the build log for whatever that's worth. Let me know if you want any config logs. On 5/2/22 11:01 AM, Zhou, Hui wrote:
Hi Allen,
The line was just getting a libtool version to be included in a comment. I suspect simply deleting the line would work fine. Could you try that?
Posting yaksa related questions here is fine. Don't worry about reposting to yaksa-users.
-- Hui ------------------------------------------------------------------------ *From:* Allen McIntosh via discuss <[email protected]> *Sent:* Monday, May 2, 2022 9:22 AM *To:* [email protected] <[email protected]> *Cc:* Allen McIntosh <[email protected]> *Subject:* [mpich-discuss] error building cuda from yaksa Mpich version: 4.0.2 OS: Ubuntu 20.04 (but likely irrelevant)
Line 45 (approximately) of mpich-4.0.2/modules/yaksa/src/backend/cuda/cudalt.sh invokes libtool without providing its own version. This results in an error if there is no system version of libtool. I got around this by changing the invocation to "./libtool", but that is pretty ugly. I have asked to have libtool-bin installed on the build system. I can post with any results.
[I see that I really should have posted this to yaksa-users. I will subscribe and post there.] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Allen McIntosh
