Re: [mpich-discuss] Problems running MPICH jobs under SLURM
For reasons unclear to me, With this tarball, I get no mpiexec compiled. I'm doing a diff between the latest tarballs and trying to find the problem ... JB ll install/bin/ total 68 lrwxrwxrwx 1 biddisco biddisco 6 Jun 9 07:55 mpic++ -> mpicxx -rwxr-xr-x 1 biddisco biddisco 9905 Jun 9 07:55 mpicc -rwxr-xr-x 1 biddisco biddisco 9300 Jun 9 07:55 mpichversion -rwxr-xr-x 1 biddisco biddisco 9458 Jun 9 07:55 mpicxx -rwxr-xr-x 1 biddisco biddisco 11551 Jun 9 07:55 mpif77 -rwxr-xr-x 1 biddisco biddisco 13375 Jun 9 07:55 mpif90 -rwxr-xr-x 1 biddisco biddisco 3430 Jun 9 07:55 parkill -----Original Message----- From: Pavan Balaji [mailto:[email protected]] Sent: 09 June 2013 07:13 To: [email protected] Cc: Biddiscombe, John A. Subject: Re: [mpich-discuss] Problems running MPICH jobs under SLURM John, Can you try the latest nightly snapshot? http://www.mpich.org/static/tarballs/nightly/master/mpich/ -- Pavan On 06/08/2013 03:23 PM, Pavan Balaji wrote:
Thanks, John. I'll look into it and get back to you if I need any more information.
Btw, you should not need sudo at all. You might have some previously left over files with root permissions that might have caused the issue. If you delete the entire directory and start from scratch, this issue should not be there.
-- Pavan
On 06/08/2013 03:02 PM, Biddiscombe, John A. wrote:
Following your instructions (I only have 1 node, so changed N2 n4 to N 1 n2), same error, listed below...
[NB . Only one interesting thing is that I cannot do a make as user biddisco and have to sudo make as it gives me some permission error otherwise mkdir -p '/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/etc' /usr/bin/install -c -m 644 src/env/mpicc.conf src/env/mpif77.conf src/env/mpif90.conf src/env/mpicxx.conf '/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/etc' /usr/bin/install: cannot remove `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/etc/mpicc.conf': Permission denied /usr/bin/install: cannot remove `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/etc/mpif77.conf': Permission denied /usr/bin/install: cannot remove `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/etc/mpif90.conf': Permission denied /usr/bin/install: cannot remove `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/etc/mpicxx.conf': Permission denied make[3]: *** [install-sysconfDATA] Error 1 make[3]: Leaving directory `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79' make[2]: *** [install-am] Error 2 make[2]: Leaving directory `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79' make[1]: *** [install-recursive] Error 1 make[1]: Leaving directory `/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79' make: *** [install] Error 2 ]
JB
biddisco@breno2 ~/build/mpich-master-v3.0.4-259-gf322ce79 $ ./install/bin/mpiexec -n 2 ./hello *** glibc detected *** ./hello: double free or corruption (fasttop): 0x00000000017b2340 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7fcaeb4a2b96] *** glibc detected *** ./hello: double free or corruption (fasttop): 0x00000000011e7340 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7fd1a77ddb96] /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPIDI_Populate_vc_node_ids+0x3f9)[0x7fd1a7bc75a9]
/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPID_Init+0x136)[0x7fd1a7bc1da6]
/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPIR_Init_thread+0x22f)[0x7fd1a7c78f1f]
/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPI_Init+0xae)[0x7fd1a7c788be]
./hello[0x40081e] /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPIDI_Populate_vc_node_ids+0x3f9)[0x7fcaeb88c5a9]
/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPID_Init+0x136)[0x7fcaeb886da6]
/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPIR_Init_thread+0x22f)[0x7fcaeb93df1f]
/home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10(MPI_Init+0xae)[0x7fcaeb93d8be]
./hello[0x40081e] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x7fcaeb44576 d] ./hello[0x400719] ======= Memory map: ======== 00400000-00401000 r-xp 00000000 08:01 10625669 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/hello 00600000-00601000 r--p 00000000 08:01 10625669 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/hello 00601000-00602000 rw-p 00001000 08:01 10625669 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/hello 017b1000-017d2000 rw-p 00000000 00:00 0 [heap] 7fcaeabe1000-7fcaeabe4000 rw-p 00000000 00:00 0 7fcaeabe4000-7fcaeabf9000 r-xp 00000000 08:01 9047556 /lib/x86_64-linux-gnu/libgcc_s.so.1 7fcaeabf9000-7fcaeadf8000 ---p 00015000 08:01 9047556 /lib/x86_64-linux-gnu/libgcc_s.so.1 7fcaeadf8000-7fcaeadf9000 r--p 00014000 08:01 9047556 /lib/x86_64-linux-gnu/libgcc_s.so.1 7fcaeadf9000-7fcaeadfa000 rw-p 00015000 08:01 9047556 /lib/x86_64-linux-gnu/libgcc_s.so.1 7fcaeadfa000-7fcaeae12000 r-xp 00000000 08:01 9050338 /lib/x86_64-linux-gnu/libpthread-2.15.so 7fcaeae12000-7fcaeb011000 ---p 00018000 08:01 9050338 /lib/x86_64-linux-gnu/libpthread-2.15.so 7fcaeb011000-7fcaeb012000 r--p 00017000 08:01 9050338 /lib/x86_64-linux-gnu/libpthread-2.15.so 7fcaeb012000-7fcaeb013000 rw-p 00018000 08:01 9050338 /lib/x86_64-linux-gnu/libpthread-2.15.so 7fcaeb013000-7fcaeb017000 rw-p 00000000 00:00 0 7fcaeb017000-7fcaeb01e000 r-xp 00000000 08:01 9050343 /lib/x86_64-linux-gnu/librt-2.15.so 7fcaeb01e000-7fcaeb21d000 ---p 00007000 08:01 9050343 /lib/x86_64-linux-gnu/librt-2.15.so 7fcaeb21d000-7fcaeb21e000 r--p 00006000 08:01 9050343 /lib/x86_64-linux-gnu/librt-2.15.so 7fcaeb21e000-7fcaeb21f000 rw-p 00007000 08:01 9050343 /lib/x86_64-linux-gnu/librt-2.15.so 7fcaeb21f000-7fcaeb223000 r-xp 00000000 08:01 8661134 /home/biddisco/apps/mpich-3.0.4/lib/libmpl.so.1.0.0 7fcaeb223000-7fcaeb422000 ---p 00004000 08:01 8661134 /home/biddisco/apps/mpich-3.0.4/lib/libmpl.so.1.0.0 7fcaeb422000-7fcaeb423000 r--p 00003000 08:01 8661134 /home/biddisco/apps/mpich-3.0.4/lib/libmpl.so.1.0.0 7fcaeb423000-7fcaeb424000 rw-p 00004000 08:01 8661134 /home/biddisco/apps/mpich-3.0.4/lib/libmpl.so.1.0.0 7fcaeb424000-7fcaeb5d9000 r-xp 00000000 08:01 9050358 /lib/x86_64-linux-gnu/libc-2.15.so 7fcaeb5d9000-7fcaeb7d8000 ---p 001b5000 08:01 9050358 /lib/x86_64-linux-gnu/libc-2.15.so 7fcaeb7d8000-7fcaeb7dc000 r--p 001b4000 08:01 9050358 /lib/x86_64-linux-gnu/libc-2.15.so 7fcaeb7dc000-7fcaeb7de000 rw-p 001b8000 08:01 9050358 /lib/x86_64-linux-gnu/libc-2.15.so 7fcaeb7de000-7fcaeb7e3000 rw-p 00000000 00:00 0 7fcaeb7e3000-7fcaeba03000 r-xp 00000000 08:01 11675463 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10.0.4
7fcaeba03000-7fcaebc03000 ---p 00220000 08:01 11675463 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10.0.4
7fcaebc03000-7fcaebc10000 r--p 00220000 08:01 11675463 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10.0.4
7fcaebc10000-7fcaebc16000 rw-p 0022d000 08:01 11675463 /home/biddisco/build/mpich-master-v3.0.4-259-gf322ce79/install/lib/li bmpich.so.10.0.4
7fcaebc16000-7fcaebc4e000 rw-p 00000000 00:00 0 7fcaebc4e000-7fcaebc70000 r-xp 00000000 08:01 9050344 /lib/x86_64-linux-gnu/ld-2.15.so 7fcaebe54000-7fcaebe56000 rw-p 00000000 00:00 0 7fcaebe6d000-7fcaebe70000 rw-p 00000000 00:00 0 7fcaebe70000-7fcaebe71000 r--p 00022000 08:01 9050344 /lib/x86_64-linux-gnu/ld-2.15.so 7fcaebe71000-7fcaebe73000 rw-p 00023000 08:01 9050344 /lib/x86_64-linux-gnu/ld-2.15.so 7fff671e5000-7fff67206000 rw-p 00000000 00:00 0 [stack] 7fff673b4000-7fff673b5000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 6 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================== ==============
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
