Re: [mpich-discuss] MPICH2-1.4.1 on Windows Server, Issues Running on More than One Node
Hello, This is a follow-up to my message below. I am running MPICH2-1.4.1 on Windows Server 2102r2 using the job scheduler with command line through PowerShell. I found this page which explains my issue https://technet.microsoft.com/pt-pt/library/cc720141(v=ws.10).aspx "An exception is the mpiexec option *-n*. Using this option will cause all of the processes to be run on the same processor, regardless of how many processors have been specified using */numprocessors:*." It's an older version, but I think is the cause of my problem. Can I use MPICH2 instead of Windows MPI with the Windows Job Scheduler? If I don't specify any "-n" parameter, I only get mpiexec to execute a single task, despite the number of processors I am trying to request I am trying to use $j=New-HpcJob $j | Add-HpcTask -numcores $NUMCORES -command "$MPIEXEC -n $NUMCORES lmp_mpi.exe -in in.lammps" $j | Submit-HpcJob where $MPIEXEC is the full path to mpiexec.exe. I am using MPICH2-1.4.1 because it works with LAMMPS and I am told Windows MPI does not because of Visual C++ compatibility with LAMMPS. I can successfully run the cpi.exe example outside the job scheduler on all cores and nodes. I can use a machinefile as well but when I use it, the cores and nodes that mpiexec executes don't follow the allocated nodes from the job scheduler. Is there anyway around using MPICH2 with the -n option in Windows Job Scheduler getting jobs to run on more than one node? Thanks again for any response I get. I've spent days trying to figure this out so would be grateful for any advice. Josh On Sun, Apr 24, 2016 at 11:49 PM, Joshua Moore <[email protected]> wrote:
Hello,
I am having issues running mpiexec when I run on more than one node.
I am using v 1.4.1 because it is compatible with LAMMPS software I am using.
I am running on Windows Server 2012r2 and trying to get MPICH2 to play nice with Window's batch server.
I've installed mpich2 on each of the nodes and the head node.
1) *msiexec /i mpich2-1.2.1-win-ia32.msi* *2) mpiexec -register (to register username and password)* *3) smpd -install (to start spmd server on **each of the nodes and the head node)* *4) On the head node, I've used smpd -sethosts hostname1 hostname2 ... to add each of the hosts. I haven't done this on the compute nodes.*
When I execute a job through Windows batch system through PowerShell, my job executes but puts all of the executions on the same node. So if for example my nodes are 16 cores, and I ask for 32 cores, 32 separate processes are run on the first node and none on the second, even though Window's scheduler is allocated 2 nodes.
It's like mpiexec is ignoring the node list that the smpd hosts is setting.
I can use a machinefile with mpiexec and this will allow me to execute on multiple nodes but it doesn't seem to follow the nodes that Windows allocates in their batch server.
I should also add that when I try to request more than one node through Window's batch server with -requestednodes "host1 host2" with new-hpcjob, Windows tells me that I can't do this because I have zero cores available. I can ask for only 1 node and up to the maximum number of cores and it is ok with this.
Any suggestions?
Thank you.
Josh
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Joshua Moore
