Re: [mpich-discuss] mpich issues when configuring
Did you add just CC=gcc? If so, configure will still detect and prefer the Intel C++ and Fortran compilers if they are present in your path. The license problem will remain. Ken On 08/21/2015 11:37 AM, Jie Ren wrote:
Hi Ken,
Thanks for your suggestion, I did try adding CC=gcc, however it keeps giving me the same errors.
Jie
On Fri, Aug 21, 2015 at 1:08 PM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
It appears that the configure script is discovering a version of icc in your path, but it is unable to compile with it. Your system may not be configured to use it. I would suggest trying different compilers if you have them available. I.e. add "CC=gcc CXX=g++ FC=gfortran" to your configure line.
Ken
On 08/21/2015 12:37 PM, Jie Ren wrote:
I met a problem when I was configuring the mpich on my linux machine as below. I also attached the package of c.txt, config.log(the main one, openpa one and mpl one, looks like I don't have the other two config.log files when I got the errors).
Jie
configure: error: in `/data/Research/Task 17 SU2 Study/mpich-3.1.1/src/openpa': configure: error: C compiler cannot create executables See `config.log' for more details configure: error: OpenPA configure failed
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
