Re: [mpich-discuss] mpiexec and DISPLAY for remote hosts
Did you try passing -enable-x to mpiexec? — Pavan
On Nov 11, 2014, at 5:00 PM, Isaila, Florin D. <[email protected]> wrote:
I am having troubles running mpiexec (from MPICH 3.1) on remote hosts with xterm (for debugging purposes) from an Ubuntu box.
The following command works perfectly in local: mpiexec -n 1 xterm
However, if I use a machine file: mpiexec -f macfile -n 1 xterm xterm Xt error: Can't open display: xterm: DISPLAY is not set
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 19225 RUNNING AT thwomp.mcs.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
X forwarding is activated: fisaila@howard:bin$ grep X11Forwarding /etc/ssh/sshd_config X11Forwarding yes
The following command works: fisaila@howard:bin$ ssh thwomp.mcs.anl.gov xterm
Any suggestion how to solve this?
Thanks Florin
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
