Re: [mpich-discuss] get the process rank in the bash script
If you are on a Cray machine, why are you not using the appropriate launcher, aprun? You can find some info on parsing Cray physical topology on https://wiki.alcf.anl.gov/parts/index.php/Cray. For example, the physical node id, which may not correspond with what PMI gives you inside of a parallel job, can be read from /proc/cray_xt/nid on every node in the system, including both compute and service nodes. I can't tell exactly what you are doing, but if you are using CSCS, you might find CSCS support is able to better address your needs. In many cases, there is a "better way" to do things on a supercomputer than what one uses on traditional Linux clusters. Jeff On Mon, Apr 29, 2013 at 9:12 PM, Pavan Balaji <[email protected]> wrote:
Hello,
Adding [email protected] back to cc.
There is a second alternative -- PMI_ID -- that you might want to try. If that doesn't work, Cray might be using something different and you'll need to check with them.
-- Pavan
On 04/29/2013 02:22 AM US Central Time, Kirill Lykov wrote:
Thanks for the reply, I'm working on the Cray machine so the MPICH2 version for cray is defined by the following line: CRAY_MPICH2_VERSION=5.6.0
________________________________________ From: Pavan Balaji [[email protected]] Sent: Monday, April 29, 2013 12:13 AM To: [email protected] Cc: Lykov Kirill Subject: Re: [mpich-discuss] get the process rank in the bash script
You can use PMI_RANK. I just tried it and it works as expected. Which version of MPICH are you using?
-- Pavan
On 02/25/2013 10:06 AM US Central Time, Kirill Lykov wrote:
Dear mpich users,
I'm looking for an environmental variable which can be used in a bash script to identify the process rank. I launch a bash script using mpi: mpirun ./my-script.sh
In my-script I want to use the rank of the process to identify which input file to use. In OpenMPI, I used OMPI_COMM_WORLD_RANK and my-script.sh looked like the following:
inputName="MyInput_$OMPI_COMM_WORLD_RANK"./myexe $inputName
What can be used in MPICH instead of OMPI_COMM_WORLD_RANK? I found somewhere that $PMI_RANK is the same but I found that it is empty.
Kirill Lykov, Mr.
Doctoral Assistant Institute of Computational Science Faculty of Informatics Università della Svizzera italiana, USI Via G. Buffi 13 CH - 6904 Lugano (e) [email protected] (t) +41 (0) 788413392
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides
participants (1)
Jeff Hammond
