Dear Gus and Dear Huiwei I would like to offer my heartfelt appreciation for your kind consideration. After Huiwei 's last post I am examining his suggestions. I have installed current version of mpich2 but it could not solve problem. utilizing same of various values for Ntilei and Ntilej can not solve problem too. Then I check swan model again. Now I am sure it is the reason of errors. I am trying to sort out what cause those errors. I find this model mailing list. Thanks again Cheers fereshte On Mon, Oct 28, 2013 at 8:03 PM, Gus Correa <[email protected]> wrote:
Hi Fereshteh
1) I would look for log or error messages in the model output *before* the final one ("MPI_Abort ...").
Although it aborted with 2 processors, that was a graceful termination by the program. So what is before the last error message may shed some light on why the model aborted, and what it requires to run correctly.
2) MCT is also used for coupling climate models that we use here. Some of these models it run in SPMD mode (i.e. a single executable is launched by mpiexec). Others run in MPMD mode (i.e. several executables are launched by mpiexec, which requires a mpiexec command line with more parameters).
Your mpiexec suggests that the model relies on a single executable (oceanG). However, this may/may not be the case, as you mentioned three separate items also: ROMS, SWAN, and the coupler.
Is it a single executable or more than one that your model uses? [If you describe how you compile the model it may help.]
3) Are you trying to run it in hybrid mode, i.e. using both MPI and OpenMP?
I am not familiar to this model, so I am just guessing.
The conventional wisdom is to use parameters names like "Nthreads" for OpenMP threads, although parameter names are elusive. OpenMP would add another twist to your processor configuration, as you would need to provision additional processors for OpenMP, besides those for MPI.
4) Does the domain decomposition (Ntilei and Ntilej) have to be the same for both models?
Have you tried something like: Ntilei=2 Ntilej=2 i.e. 2*2=4 processors for the ocean plus one processor for SWANN, a total of 5 processors, then:
mpiexec -np 5 ...
In some models we run here (e.g. MITgcm) you need to match precisely the number of processors to the tiles used to decompose your domain (and possibly also the OpenMP threads).
When you tried mpiexec -np 2, did you choose Ntilei=Ntilej=Nthreads=1 for both models?
Do you have perhaps to add one processor (or more) specifically for the coupler?
5) Do your input files (describing the ocean initial state, and perhaps the wave state), have to be organized based on the "tile" configuration, or can they span the whole domain? This could be another source of error.
6) Does ROMS and SWANN have mailing lists that can perhaps help you more than the generic MPICH list?
I hope this helps, Gus Correa
On 10/27/2013 06:33 AM, fereshteh komijani wrote:
Sure.
ROMS and SWAN models are models for ocean and wave models, respectively. Coupling of them require 3 input files: coupling_test.in <http://coupling_test.in>, swan_test.in <http://swan_test.in> and roms_test.in <http://roms_test.in> which first one is coupled input file
and also one build.bash file which in it user called requested libraries, cpp optins, header file, compilers (for me gcc and gfortran). For example in build.bash file I set
USE_MPI=on = on USE_MPIF90 =on
WHICH_MPI=mpich2
FORT = gfortran
also with regard that for coupling model, MCT (model coupling toolkit) is necessary I have installed it and set its include and lib directories in build.bash file.
In coupling_test.in <http://coupling_test.in> user call swan_test.in <http://swan_test.in>and roms_test.in <http://roms_test.in> as wave and ocean model's inputs.
In roms_test.in <http://roms_test.in> some coefficients, solving
technique and some input forcing file determined.
for choosing number of nodes for each model there are NtileI and Ntilej in roms_test.in <http://roms_test.in> and Nthreads (ocean) and Nthreads (wave) in coupling_test.in <http://coupling_test.in> file ( Nthreads
(ocean)=NtileI *Ntilej ) and total nodes are equal to Nthreads (ocean)+Nthreads (wave).
whenever i set one node for wave model (SWAN) (Nthreads (wave)=1) after running by
mpirun -np 2 ./oceanG coupling_inlet-test.in <http://coupling_inlet-test.**in/ <http://coupling_inlet-test.in/>
mpi.log
it replies:
application called MPI_Abort(comm=0x84000002, 4) - process 0
But when setNthreads (wave)>1 (and everything for Nthreads (ocean)) for
example
mpirun -np 8 ./oceanG coupling_inlet-test.in <http://coupling_inlet-test.**in/ <http://coupling_inlet-test.in/>
mpi.log
mpi.log file (attaché file) shows that roms model does not have problems and its nodes are active but nothing happen for swan model after 2 weeks than running.
I hope that this information be sufficient.
All the best
fereshte
______________________________**_________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/**mailman/listinfo/discuss<https://lists.mpich.org/mailman/listinfo/discuss>
-- ***Angel*** **
participants (1)
fereshteh komijani
