Re: [mpich-discuss] MPI / openmp - big static arrays fortran
Because the module could be used in a routine, not just the main program, Fortran probably allocates it off of the stack (the way it manages memory). If there is one thread, then it is easy to make that stack very large. If multiple threads *might* be used, it gets harder. Typically, the Fortran compiler and runtime divides the memory in to multiple stacks, one for each (potential) thread. This reduces the amount of space available to each thread’s stack, and can cause problems with data that is allocated on the stack. The two common options are (a) don’t allocate the space like this - allocate it dynamically or (b) tell the compiler that you need larger stacks for the threads. Bill On Mar 15, 2015, at 5:25 AM, Jan Wittke <[email protected]> wrote:
I have a strange problem. When I compile this code:
module user implicit none
type user_type real :: value integer, dimension(30,30) :: array end type
end module
program test_mpi use user implicit none
integer, parameter :: num = 1e5 type(user_type), dimension(num) :: var
var(1)%value = 19.
write(*,*) var(1)%value
end program
with gfortran and run it there is no problem. Now If I compile this program with
mpifort -fcoarray=lib -fopenmp testmod.f95 -lcaf_mpi
and run it with
mpirun -np 1 ./a.out
I got an error Segmentation fault (signal 11)
Now if if compile it with
mpifort -fcoarray=lib testmod.f95 -lcaf_mpi
everything is fine. Why is it a problem to add the option -fopenmp with this code? Doing some web searches suggests that using big static array will not work .
Thanks Jan _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
William Gropp
