Re: [mpich-discuss] Fatal error in PMPI_Barrier: A process has failed, error stack:
Rajeev There is a firewall on svr but its configured to accept all packets on the interface connected to the internal domain (where pc5 lives). I had already checked that stopping iptables off made no difference, but I just tried it again on the cpi example. The result was the same. Tony On 03/26/2014 09:45 PM, Rajeev Thakur wrote:
Is there a firewall on either machine that is in the way of communication?
Rajeev
On Mar 26, 2014, at 8:28 PM, Tony Ladd <[email protected]> wrote:
No - you get the same error - it looks as if process 1 (on the remote node) is not starting
svr:tladd(netbench)> mpirun -n 2 -f hosts /global/usr/src/mpich-3.0.4/examples/cpi Process 0 of 2 is on svr.che.ufl.edu Fatal error in PMPI_Reduce: A process has failed, error stack: PMPI_Reduce(1217)...............: MPI_Reduce(sbuf=0x7fff30ecced8, rbuf=0x7fff30ecced0, count=1, MPI_DOUBLE,
But if I reverse the order in the host file (pc5 first and then svr) apparently both processes start
svr:tladd(netbench)> mpirun -n 2 -f hosts /global/usr/src/mpich-3.0.4/examples/cpi Process 1 of 2 is on svr.che.ufl.edu Process 0 of 2 is on pc5 Fatal error in PMPI_Reduce: A process has failed, error stack: PMPI_Reduce(1217)...............: MPI_Reduce(sbuf=0x7fff4d776348, rbuf=0x7fff4d776340, count=1, MPI_DOUBLE,
But with the same result in the end.
Tony
On 03/26/2014 08:18 PM, Rajeev Thakur wrote:
Does the cpi example run across two machines?
Rajeev
On Mar 26, 2014, at 7:13 PM, Tony Ladd <[email protected]> wrote:
Rajeev
Sorry about that. I was switching back and forth from openmpi to mpich. But it does not make a difference. Here is a clean log from a fresh terminal - no mention of openmpi
Tony
PS - its a CentOS 6.5install - should have mentioned it before.
-- Tony Ladd
Chemical Engineering Department University of Florida Gainesville, Florida 32611-6005 USA
Email: tladd-"(AT)"-che.ufl.edu Web http://ladd.che.ufl.edu
Tel: (352)-392-6509 FAX: (352)-392-9514
<mpich.log>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Tony Ladd
-- Tony Ladd Chemical Engineering Department University of Florida Gainesville, Florida 32611-6005 USA Email: tladd-"(AT)"-che.ufl.edu Web http://ladd.che.ufl.edu Tel: (352)-392-6509 FAX: (352)-392-9514
participants (1)
Tony Ladd
