Re: [mpich-discuss] Crash on one node cause all programm termination.
Hi Andris, Unfortunately right now the MPI standard leaves the behavior upon failures pretty open to implementations. With the current implementation, you can pass the flag "-disable-auto-cleanup" to mpiexec (Hydra) to prevent it from killing the non-failing processes. But, bear in mind that you shouldn't use those communicators that involved the failing process anymore. So, what you say is somehow possible if you use MPI_Comm_spawn to create the slaves and set the error handler MPI_ERRORS_RETURN in the intracommunicator. Again, this is something not defined in the standard, and hence there's no guarantee it'll work in all conditions and/or MPI implementations. On the other hand, you can search and take a look at the ULFM proposal. I hope this helps. Best, Antonio On 29/01/16 14:29, Andris wrote:
Hello! I'm a newbie in MPI world. I have some question about program execution. I build some program (for example, exp1) using mpicc and run it to multiple hosts. mpiexec -f my_hosts -n 8 ./exp1 4 exp1 are running on host A (rank 0-3) and 4 - on host B (rank 4-7). If one of them crashes, all other are terminating too. mpiexec print: =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 5774 RUNNING AT slave1 = EXIT CODE: 11 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
If I understand right, I can handle in my code only MPI function errors. In my project I need if one process is terminated, all other processes will stay running. For example, if slave node lose power, processes on master node stay running. Master node will know that processes on slave node are terminated and after some time master node will rerun these processes on slave node. Is it possible? If yes, how?
Big thanks!
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Pe�a, PhD Senior Researcher Barcelona Supercomputing Center http://www.bsc.es/about-bsc/staff-directory/pena-antonio WARNING / LEGAL TEXT: This message is intended only for the use of the individual or entity to which it is addressed and may contain information which is privileged, confidential, proprietary, or exempt from disclosure under applicable law. If you are not the intended recipient or the person responsible for delivering the message to the intended recipient, you are strictly prohibited from disclosing, distributing, copying, or in any way using this message. If you have received this communication in error, please notify the sender and destroy and delete any copies you may have received. http://www.bsc.es/disclaimer _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Antonio J. Peña
