Re: [mpich-discuss] mpi_comm_connect hangs in client/server mode runs in multiple process
Hi, Joachim, Thanks a lot for your response. Is that possible that the rank 0 in server can talk to each process in the client? If that's possible, I just need to replace MPI_COMM_WORLD by MPI_COMM_SELF on the server side, right? Thanks, Shuwei On Wed, Feb 20, 2019 at 5:11 PM Protze, Joachim <[email protected]> wrote:
Shuwei,
Both MPI calls are collective calls. This means all ranks in the provided communicator must call this function. If you want to connect both applications so that any rank in server can communicate with any rank in client, all processes need to call the function for each side. If only rank 0 should ever communicate, you can replace MPI_COMM_WORLD by MPI_COMM_SELF on both sides. The resulting newcomm will be a intercommunicator with one rank on each side.
Best Joachim
-- Sent from my mobile phone
On Wed, Feb 20, 2019 at 10:54 PM +0100, "Shuwei Zhao via discuss" < [email protected]> wrote:
I was trying to study the usage of mpi client-server model based on the example you provided on https://www.mcs.anl.gov/research/projects/mpi/mpi-standard/mpi-report-2.0/no.... After writing simple separate client and server source file based on the samples on your website. I found that: 1) when client and server both runs in single process like mpiexec -n 1 server, mpiexec -n 1 client. it works fine, connection between server and client can successfully be built. 2) when client runs in single process but server runs in multiple processes (2 for example) but only rank 0 in server responsible to call mpi_comm_accept, rank 1 of server is just sleeping. Usage is like mpiexec -n 1 client, mpiexec -n 2 server. In this case, server blocks in mpi_comm_accept, which is expected. However, client blocks in mpi_comm_connect which is not expected. 3) when client runs in multiple processes and server runs in multiple processes, only rank 0 of client responsible for mpi_comm_connect and only rank 0 of server responsible for mpi_comm_accept. In this case, same observation in 2).
May I ask is the hanging of mpi_comm_connect in 2) & 3) expected? Is there a way to build connection successfully when mpi client/server runs under multi-process?
Thanks a lot, Shuwei
participants (1)
Shuwei Zhao
