Re: [mpich-discuss] pgf90-Error-Unknown switch: -pthread
Libtool is adding the -pthread flag because it exists in the "inherited_linker_flags" in libpmi.la. However, PGI clearly doesn't understand it. The libtool devs called this issue a bug when it was reported here: http://lists.gnu.org/archive/html/libtool/2010-11/msg00034.html You could either remove the flag from the /usr/lib/libpmi.la file, or use the workaround suggested by Gus Correa to finish your build. Ken On 07/09/2014 05:56 PM, Gus Correa wrote:
Hi James
Adding '-noswitcherror' to the CFLAGS, FFLAGS, FCFLAGS, may be a workaround to this problem.
My two cents, Gus Correa
On 07/09/2014 05:55 PM, James Long wrote:
I need to use srun to launch mpi jobs under slurm, so configured mpich-3.1.1 with
$ env CC=pgcc FC=pgf90 CXX=pgCC CPPFLAGS="-DNDEBUG -DpgiFortran" CFLAGS="-O2" FFLAGS="-O2 -w" ./configure --prefix=/opt/mpich-slurm --with-pmi=slurm --with-pm=no --with-slurm-include=/usr/include/slurm --with-slurm-lib=/usr/lib/slurm --enable-fortran=yes
The following error occurs when compiling:
CC src/mpid/common/datatype/lib_libmpi_la-mpir_type_flatten.lo CC src/mpid/common/sched/lib_libmpi_la-mpid_sched.lo CC src/mpid/common/thread/lib_libmpi_la-mpid_thread.lo CC src/mpi_t/lib_libmpi_la-mpit.lo CC src/nameserv/pmi/lib_libmpi_la-pmi_nameserv.lo GEN lib/libmpi.la pgf90-Error-Unknown switch: -pthread make[2]: *** [lib/libmpi.la] Error 1 make[2]: Leaving directory `/home/boss/mpich-3.1.1' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/boss/mpich-3.1.1' make: *** [all] Error 2
config.log is at http://pastebin.com/aB8CZsr0
Jim --
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% James Long International Arctic Research Center University of Alaska Fairbanks jlong|at|alaska.edu (907) 474-2440 %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
