Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
On 06/16/2013 07:37 AM, Lee, Eibhlin wrote:
Just to clarify: you were able to run the program that accesses /dev/mem not just mpiexec id?
I didn't run your application, but it doesn't matter. As I pointed out the primary problem you have is that your application processes are not running as root. If you don't fix that, you can't expect your application to work. I confirmed that you can run Hydra as root correctly. Till you get to that stage, I don't think we can do anything to help you.
I did not want to spend a whole day installing hydra instead of smpd if it would not work.
Well, all I can do is discourage you from using it. It's finally your call. But we can't spend more time debugging this for you unless you follow our recommendations. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
