Re: [mpich-discuss] Bug reporting for some mpi/rma tests
Hi Min, Although it may have been fixed in later version (as I am currently using test suite from mpich 3.1), the window creation (l.125) is stated as follow : MPI_Win_create( rmabuffer, bufsize, sizeof(int), MPI_INFO_NULL, MPI_COMM_WORLD, &win ); with bufsize being equal to RMA_SIZE (2048) on master's side, and 0 on partner side. However, the bufsize argument is the size of the window in bytes, not in "displacement_unit" (here being sizeof(int) ). so the range is int[157: 157+512], but the window is defined with a range int[0: RMA_SIZE / sizeof(int)], creating an overflow. Clément FOYER Message: 1
Date: Tue, 12 Jul 2016 09:46:59 -0500 From: Min Si <[email protected]> To: <[email protected]> Subject: Re: [mpich-discuss] Bug reporting for some mpi/rma tests Message-ID: <[email protected]> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Hi C. FOYER,
Thanks for reporting bugs to us.
However, the places in test rma/lockcontention3.c are correct. The buffers' size is RMA_SIZE (2048) count of int. In case 9, 10, 11 the operations' size is longcount(512) count of int, and the largest target displacement is OFFSET_3(157), which means the window buffer is accessed in range int[157: 157+512]. Thus no overflows.
In rma/manyrma3.c, as you reported, we missed verification and winbuf initialization. We will fix it.
Min
On 7/12/16 3:08 AM, Cl?ment Foyer wrote:
Hi everyone,
I think I may have found some bugs in mpich tests for RMA operations.
First, in rma/lockcontention3.c. When calling RMA operations, the different offsets are not taken in account on the origin_count and target_count parameters. As the buffers are the same sizes, when the count arguments are equal to "longcount" (such as in the tests cases 9, 10 and 11), it either overflows when the operation is actually done, or, as it should preferably be done, it fails with the returns of the MPI_ERR_RMA_RANGE error code. Also, on the check function, there are some array overflows, as the loops go from 0 to longcount-1, and the array is accessed with the OFFSET (buf[OFFSET_1+j]). The easiest solution would be to set bufsize (l.111) and getbufsize (l.118) to RMA_SIZE+OFFSET_3 (OFFSET_3 being the bigger one), and maybe allocate change l.123 to srcbuf = malloc((RMA_SIZE + OFFSET_3)*sizeof(*srcbuf)); Also, the window is defined with the bufsize as size, which should mean that the window is bufsize bytes long. But as it is an array of int's, it would rather be bufsize*sizeof(int) long. There might be a problem there as well, given the fact that the displacement unit given is actually "sizeof(int)".
rma/manyrma3.c No verification is done. Just accumulate, and then we assume the result is correct. Also, winbuf is not initialized.
Sincerely yours,
C. FOYER
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Clément Foyer
