Re: [mpich-discuss] MCS lock and MPI RMA problem
Thanks. That's a bug in your code. In mcs-lock-fop.c:92, before you do an accumulate to notify the next rank, you need to reset your lmem[nextRank] back to -1. Otherwise, in the next iteration, you'll think that the value is set even if it is not. You can either do it using a local store followed by an MPI_WIN_SYNC or using MPI_Put or MPI_Accumulate. After that fix your program seems to work correctly. I also found that it was not a bug in the MPI implementation, after all. Even without the MODE_NOCHECK hint, the program seems to work correctly now. Nevertheless, this is a good regression test to have and we'd like to include it in our test harness. Would you mind providing this as a contribution to mpich? You'd need to sign the contributors' agreement for it: http://www.mpich.org/documentation/contributor-docs/ FWIW, here's the new code that includes the send/recv optimization that I pointed out in my previous email. Thanks, -- Pavan
On Mar 14, 2017, at 2:03 PM, Ask Jakobsen <[email protected]> wrote:
$ mpicc -Wall main.c mcs-lock-fop.c
$ while true; do mpiexec -n 2 ./a.out ; done
At some point it does locks up.
On Tue, Mar 14, 2017 at 7:52 PM, Balaji, Pavan <[email protected]> wrote:
Thanks. I can't seem to reproduce the deadlock anymore after the MODE_NOCHECK hint. Can you tell us how to reproduce it?
-- Pavan
On Mar 14, 2017, at 1:43 PM, Ask Jakobsen <[email protected]> wrote:
Sorry, now header file is attached.
On Tue, Mar 14, 2017 at 5:11 PM, Balaji, Pavan <[email protected]> wrote:
On Mar 14, 2017, at 4:58 AM, Ask Jakobsen <[email protected]> wrote: The MPI_Fetch_and_op version trying to implement Pavan's ideas as I understand it (no async progress necessary, but also tested with it enabled).
The header file is missing.
-- Pavan
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
<mcs-lock.h>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Ask Jakobsen R&D
Qeye Labs Lersø Parkallé 107 2100 Copenhagen Ø Denmark
mobile: +45 2834 6936 email: [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
