Re: [mpich-discuss] turning off MPI abort messages
On Fri, Feb 21, 2014 at 4:32 PM, Barry Smith <[email protected]> wrote:
Jeff,
Thanks. This is certainly a useful thing.
It's only half a solution right now. Hacking Hydra is a bit more difficult for me. Not sure how long before I can solve that in a manner that the MPICH folks find acceptable.
I never meant to kick a hornet’s nest with my initial email. I was taught by my postdoctoral advisor that any library or package that had stdout or stderr output hardwired that could not be turned off without losing functionality was rude and poorly thought out but then that guy probably never amounted to anything I guess so I should just ignore him since he doesn’t represent main stream thought.
A colleague of mine suggested that libraries shouldn't be calling MPI_Abort but rather return an error code to the application and let them decide how to handle it, but he learned MPI from Bill Gropp, so he might not know anything ;-) I apologize for being unpleasant earlier. Best, Jeff
Barry
On Feb 21, 2014, at 3:10 PM, Jeff Hammond <[email protected]> wrote:
Barry:
Would the following behavior be acceptable to you? I have only made the changes in MPI but am looking at the process manager now.
Jeff
# Without the process manager
alcfwl181:build jhammond$ export MPIR_CVAR_SUPPRESS_ABORT_MESSAGE=0 alcfwl181:build jhammond$ ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 alcfwl181:build jhammond$ export MPIR_CVAR_SUPPRESS_ABORT_MESSAGE=1 alcfwl181:build jhammond$ ./a.out
alcfwl181:build jhammond$ unset MPIR_CVAR_SUPPRESS_ABORT_MESSAGE alcfwl181:build jhammond$ ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
# With the process manager
alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 0 ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61023 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== alcfwl181:build jhammond$ mpiexec -n 1 -env MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 1 ./a.out
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61026 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== alcfwl181:build jhammond$ mpiexec -n 1 ./a.out application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 61032 RUNNING AT alcfwl181.alcf.anl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
On Thu, Feb 20, 2014 at 11:33 AM, Barry Smith <[email protected]> wrote:
Is there any way to turn off MPICH (and others) printing messages about MPI_Abort? We have already prepared and presented useful error messages to the user about the situation and would like to avoid having these additional messages printed (that often make the situation look worse than it is)
Thanks
Barry
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0 [cli_0]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
==================================================================mailto:[email protected]================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 56 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
