Re: [mpich-discuss] libmpi.so.12 error
Hi Ken When I run that code I get the following error -------------------------------------------------------------------------- mpiexec was unable to launch the specified application as it could not find an executable: Executable: -l Node: raspberrypi while attempting to start process rank 0. -------------------------------------------------------------------------- Sophie On 9 September 2014 02:07, Kenneth Raffenetti <[email protected]> wrote:
Let's try to verify that the library is properly located on all the nodes you are running. We can do a simple test with mpiexec. Try running:
mpiexec -n 4 -machinefile /home/pi/mpi_testing/__machinefile -l ls /home/rpimpi/mpich3-install/lib/libmpi.so.12
Ken
On 09/08/2014 07:03 PM, Sophie Norman wrote:
Hi Ken, Yes I used mpicc to build the binary
the oputput of mpicc -show is
gcc -I/home/rpimpi/mpich3-install/include -L/home/rpimpi/mpich3-install/lib -Wl,-rpath -Wl,/home/rpimpi/mpich3-install/lib -Wl,--enable-new-dtags -lmpi -lrt -lpthread
Sophie
On 9 September 2014 00:48, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
Did you use mpicc to build your binary? What is the output of 'mpicc -show'. The compile wrappers should encode an RPATH tag in your program so that setting an LD_LIBRARY_PATH to find libmpi.so is unncessary.
Ken
On 09/08/2014 06:44 PM, Sophie Norman wrote:
When running NAS parallel benchmarks using 4 Raspberry Pi nodes each running MPICH-3.1.2 I get the following error when I try to run the integer sort benchmark
~/NPB3.3/NPB3.3-MPI/bin $ mpiexec -n 4 -machinefile /home/pi/mpi_testing/__machinefile ./is.S.4
NAS Parallel Benchmarks 3.3 -- IS Benchmark
Size: 65536 (class S) Iterations: 10 Number of processes: 1
ERROR: compiled for 4 processes Number of active processes: 1 Exiting program!
./is.S.4: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory ./is.S.4: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory ./is.S.4: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory
I have tried export LD_LIBRARY_PATH=$LD_LIBRARY___PATH:/home/rpimpi/mpich3-__ install/lib on each of the nodes, and each node works individually when run with the file ./is.S.1
$ldd ./is.S.4 give the following output for the master node
/usr/lib/arm-linux-gnueabihf/__libcofi_rpi.so (0xb6edf000) libmpi.so.12 => /home/rpimpi/mpich3-install/__lib/libmpi.so.12 (0xb6ca3000) libc.so.6 => /lib/arm-linux-gnueabihf/libc.__so.6 (0xb6b68000) librt.so.1 => /lib/arm-linux-gnueabihf/__librt.so.1 (0xb6b59000) libpthread.so.0 => /lib/arm-linux-gnueabihf/__libpthread.so.0 (0xb6b3a000) libgfortran.so.3 => /usr/lib/arm-linux-gnueabihf/_ _libgfortran.so.3 (0xb6a93000) libm.so.6 => /lib/arm-linux-gnueabihf/libm.__so.6 (0xb6a22000) libgcc_s.so.1 => /lib/arm-linux-gnueabihf/__libgcc_s.so.1 (0xb69fa000) /lib/ld-linux-armhf.so.3 (0xb6eed000)
please help
Thanks
Sophie
_________________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/__mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Sophie Norman
