Communication Error when installing MPICH on multi HOSTS.
HI. My environment: Two Vmware VMs with ubuntu-server12.04 OS, called mpimaster,mpislaver1 they both linked to a virtual network 10.0.0.1; they can ssh to each other without password; I have disabled the fire walls with "sudo ufw disable" I install mpich3.0.4 on a NFS servered by mpimaster. I installed mpich3.0.4 follow the "readme.txt", it has Communication problem when progresses from different host comunicate with each other. From picture above we can see it's ok to run "cpi" on both hosts separately. If you can't see the picture,plz see the shell's below. ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -n 4 ./examples/cpi Process 0 of 4 is on mpimaster Process 1 of 4 is on mpimaster Process 2 of 4 is on mpimaster Process 3 of 4 is on mpimaster pi is approximately 3.1415926544231239, Error is 0.0000000008333307 wall clock time = 0.028108 ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -hosts mpimaster -n 4 ./examples/cpi Process 2 of 4 is on mpimaster Process 0 of 4 is on mpimaster Process 1 of 4 is on mpimaster Process 3 of 4 is on mpimaster pi is approximately 3.1415926544231239, Error is 0.0000000008333307 wall clock time = 0.027234 ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -hosts mpislaver1 -n 4 ./examples/cpi Process 0 of 4 is on mpislaver1 pi is approximately 3.1415926544231239, Error is 0.0000000008333307 wall clock time = 0.000093 Process 1 of 4 is on mpislaver1 Process 2 of 4 is on mpislaver1 Process 3 of 4 is on mpislaver1 ailab@mpimaster:~/Downloads/mpich-3.0.4$ mpiexec -hosts mpimaster,mpislaver1 -n 4 ./examples/cpi Process 0 of 4 is on mpimaster Process 2 of 4 is on mpimaster Fatal error in PMPI_Reduce: A process has failed, error stack: PMPI_Reduce(1217)...............: MPI_Reduce(sbuf=0x7fff73a51ce8, rbuf=0x7fff73a51cf0, count=1, MPI_DOUBLE, MPI_SUM, root=0, MPI_COMM_WORLD) failed MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(779)..........: MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(835)..........: MPIR_Reduce_binomial(144).......: MPIDI_CH3U_Recvq_FDU_or_AEP(667): Communication error with rank 1 MPIR_Reduce_intra(799)..........: MPIR_Reduce_impl(1029)..........: MPIR_Reduce_intra(835)..........: MPIR_Reduce_binomial(206).......: Failure during collective ================================================================================ = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ================================================================================ [proxy:0:1@mpislaver1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:886) [proxy:0:1@mpislaver1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c [proxy:0:1@mpislaver1] main (./pm/pmiserv/pmip.c:206): demux engine error waitin [mpiexec@mpimaster] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_ [mpiexec@mpimaster] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wa [mpiexec@mpimaster] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:21 [mpiexec@mpimaster] main (./ui/mpich/mpiexec.c:331): process manager error waiti ailab@mpimaster:~/Downloads/mpich-3.0.4$ plz help,THX! ------------------ Jie-Jun Wu Department of Computer Science, Sun Yat-sen University, Guangzhou, P.R. China
participants (1)
维洛逐风
