segment fault when using knem
Hello, I am doing some tests with mpich in a dual-processor SMP server. Now I use mpich-3.0.3, I also use knem for accelerating intra-node communication. The channel I used is nemesis:tcp, and nemesis-local-lmt=knem. But when I use osu_benchmarks to do the bandwidth test, osu_bw will segment fault at the 2MB, which is the default value of MPICH_NEM_LMT_DMA_THRESHOLD. It seems when DMA channel in knem is used, the segment fault occurs. When I set MPICH_NEM_LMT_DMA_THRESHOLD to a smaller value, such as 131072, osu_bw will segment fault at 131072. I also test NAS Parallell Benchmark. I noticed when DMA channel in knem is used, sometimes the NPB tests will be freezed after running for a while. In the attachment, I list some config and core dump files. Did anyone met or solved the similar problems. Thanks for your help.
participants (1)
M Xie
