Re: [mpich-discuss] problem with MPI_SCATTERV
Hi Junchao, Thanks for pointing out this. It works after I changed the recvcnt value to the maximum number of elements in receive buffer (integer). Danyang On 28/11/2013 3:13 PM, Junchao Zhang wrote:
The second scounts in your code is suspicious. According to http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Scatterv.html, sendcnts and recvcnt are of different types.
--Junchao Zhang
On Thu, Nov 28, 2013 at 2:29 PM, Danyang Su <[email protected] <mailto:[email protected]>> wrote:
Hi All,
I ran into a problem with MPI_SCATTERV. When the sendcounts (scounts in code) is the same for every process, it works fine, but if the sendcounts is different (e.g., 1, 2, 3, 4 for 4 processes, respectively), there will be error as follows:
Fatal error in PMPI_Scatterv: Message truncated, error stack: PMPI_Scatterv(376)................: MPI_Scatterv(sbuf=0000000000000000, scnts=0000000000E16CD0, displs=0000000000E16CA0, MPI_INT, rbuf=0000000002BD0050, rcount=1, MPI_INT, root=0, MPI_COMM_WORLD) failed MPIR_Scatterv_impl(187)...........: MPIR_Scatterv(144)................: MPIDI_CH3U_Receive_data_found(129): Message from rank 0 and tag 6 truncated; 16 bytes received but buffer size is 4
The code is simple as follows:
call MPI_SCATTERV(ja_in, *scounts*, displs, MPI_INT, ja, *scounts*, MPI_INT, 0, comm , ierr)
ja_in is allocated for process #0 and ja is allocated for every process. The size of ja_in and ja is big enough to hold large dataset.
Thanks and regards,
Danyang
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Danyang Su
