Re: [mpich-discuss] mpi windows with groups mpich2
I've just built 3.1 on my laptop and the program runs fine. I'll have to bug the sys admins to upgrade to MPICH3.1 on the machine I want to run on. Thanks for you time, Helen On 4/28/14 11:27 AM, Helen Kershaw wrote:
Will do.
On 4/28/14 11:24 AM, Rajeev Thakur wrote:
Can you try the latest, 3.1.
Rajeev
On Apr 28, 2014, at 12:21 PM, Helen Kershaw <[email protected]> wrote:
Version 3.0.4.
Helen
On 4/28/14 10:38 AM, Rajeev Thakur wrote:
The program runs fine on my Mac laptop. Which version of MPICH are you using?
Rajeev
On Apr 28, 2014, at 10:41 AM, Helen Kershaw <[email protected]> wrote:
I'm trying to use MPI one-sided communication with sub-communicators. I've put my test code at the end of the email. It runs on 8 processors, creates two communicators, makes a window on the communicators, then tries to do some one-sided communication.
I can use groups OR windows without a problem, but when I use them together (in the test code) I get a coredump from the first 4 tasks. I think the one-sided communication may be using the local rank in the sub-communicator (mpi_comm_grid) as if it is the global rank in mpi_comm_world.
I can run the test code ok using open-mpi, but not mpich2. I might be missing something obvious.
Thanks for your help, Helen
----- program test_group_win
use mpi
implicit none
! mpi integer :: rank, size, ierr, status(mpi_status_size) ! groups integer, parameter :: group_size = 4 integer :: group_members(group_size) integer :: group_all ! mpi_comm_world group integer :: subgroup integer :: mpi_comm_grid integer :: local_rank ! rank within subgroup
! window integer :: win integer ::bytesize !> size in bytes of each element in the window integer(KIND=MPI_ADDRESS_KIND) :: window_size pointer(aa, duplicate) real :: duplicate(*) integer(KIND=MPI_ADDRESS_KIND) :: target_disp !> displacement in window integer :: owner real :: result
call mpi_init(ierr) call mpi_comm_size(mpi_comm_world, size, ierr) call mpi_comm_rank(mpi_comm_world, rank, ierr)
! create groups call mpi_comm_group(mpi_comm_world, group_all, ierr)
if (rank < 4 ) then group_members = (/0,1,2,3/) else group_members = (/4,5,6,7/) endif
call mpi_group_incl(group_all, group_size, group_members, subgroup, ierr) call mpi_comm_create(mpi_comm_world, subgroup, mpi_comm_grid, ierr) call mpi_comm_rank(mpi_comm_grid, local_rank, ierr) ! rank within group
! create window call mpi_type_size(mpi_real, bytesize, ierr) window_size = bytesize ! one element in the window aa = malloc(1) call MPI_ALLOC_MEM(window_size, mpi_info_null, aa, ierr)
duplicate(1) = rank
call mpi_win_create(duplicate, window_size, bytesize, MPI_INFO_NULL, mpi_comm_grid, win, ierr)
! grabbing data from rank above if (rank < 3 ) then owner = rank + 1 elseif (rank < 7) then owner = rank + 1 - 4 else owner = 0 endif
print*, 'rank owner', rank, owner
target_disp = 0
call mpi_win_lock(MPI_LOCK_SHARED, owner, 0, win, ierr) call mpi_get(result, 1, mpi_real, owner, target_disp, 1, mpi_real, win, ierr) call mpi_win_unlock(owner, win, ierr)
print*, 'rank, result ', rank, result
! free window call mpi_win_free(win, ierr) call mpi_free_mem(duplicate, ierr)
call mpi_finalize(ierr)
end program test_group_win ----
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Helen Kershaw
