Re: [mpich-discuss] _get_addr error while running application using MPICH
I should clarify one piece of how mpiexec works: % ./real.exe and % mpirun -np 1 ./real.exe are equivalent. % mpirun ./real.exe uses some number of processes depending on the environment. For unmanaged clusters, that's typically 1. For clusters that have some job management system (such as slurm or pbs), mpiexec will figure out how many nodes you allocated and use all of the cores allocated to that job. My guess is that real.exe has some dependencies that are met on the local machine, but not on other machines. So when mpiexec tries to launch real.exe on other nodes, it's throwing an error. This is not an mpiexec problem, but you might want to use the -prepend-pattern option in mpiexec to figure out where the error is coming from. Something like this: mpiexec -prepend-pattern %h ./real.exe -- Pavan
On Nov 4, 2018, at 10:27 AM, Zhifeng Yang via discuss <[email protected]> wrote:
Hi
After I installed mpich and used it in a FORTRAN code. There is an error while running this FORTRAN code called real.exe by using the following command
$./real.exe or $mpirun ./real.exe real.exe: error: _get_addr: No such file or directory real.exe: error: _get_addr: No such file or directory real.exe: error: _get_addr: No such file or directory Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(784).....: MPID_Init(1323)...........: channel initialization failed MPIDI_CH3_Init(120).......: MPID_nem_init_ckpt(852)...: MPIDI_CH3I_Seg_commit(364): PMI_Barrier returned -1
But while using mpirun with specifying number of processors. as follows $mpirun -np 1 ./real.exe There is no error any more. I am not sure why? do you have any explanation? Thank you very much
Best regards Zhifeng
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
