Re: [mpich-discuss] Troubles compiling mpich 3.1.3 and 3.1.4 with MX
Thank you !!!, I will give it a whirl and let you know :-) cheers, Caroline On 03/13/2015 07:30 AM, Kenneth Raffenetti wrote:
Hi Caroline,
You can try the attached patch to fix the library name for myriexpress. The patch requires re-running autogen.sh in the base mpich directory, which means you'll have to have autoconf/automake/libtool installed and up-to-date on your machine.
I also wanted to point out that support for the MX netmod is dropped in the MPICH 3.2 series.
Thanks, Ken
On 03/12/2015 03:08 PM, Caroline Papadopoulos wrote:
Dear list,
I am having issues compiling the following versions of mpich:
3.1.3 3.1.4
but
3.1.2 and earlier versions compile just fine.
I am using the same compile options except MYINSTALLDIR is updated to the correct version:
export MYINSTALLDIR=/export/home/root/bin/mpich-3.1.3_pgi-15.3 export CC=pgcc export CXX=pgcpp export F77=pgfortran export FC=pgf90 unset F90 export CFLAGS='' export CXXFLAGS=${CFLAGS} export FFLAGS=${CFLAGS} export FCFLAGS=${FFLAGS} unset F90FLAGS ./configure --prefix=${MYINSTALLDIR} --with-device=ch3:nemesis:mx --with-mx-include=/opt/mx/include --with-mx-lib=/opt/mx/lib >& config.txt make >& make.txt make install >& make_install.txt
The error that I am getting for 3.1.3 and 3.1.4 is:
CC src/pmi/simple/lib_libmpi_la-simple_pmiutil.lo CC src/pmi/simple/lib_libmpi_la-simple_pmi.lo GEN lib/libmpi.la /usr/bin/ld: cannot find -lmx make[2]: *** [lib/libmpi.la] Error 2 make[2]: Leaving directory `/export/home/root/src/mpich-3.1.3' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/export/home/root/src/mpich-3.1.3' make: *** [all] Error 2
In fact the mx library is called:
libmyriexpress.a libmyriexpress.so
rather than libmx.a and libmx.so
So is there a configure option to have it use -lmyriexpress instead of -lmx ??
This all works fine up to 3.1.3, so for now I am just going to use 3.1.2 but did want to update to the newest version 3.1.4.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- == Caroline Papadopoulos Physical Oceanography Research Division == Scripps Institution of Oceanography == office:450 Nierenberg Hall 9500 Gilman Drive, Dept 0230 == email:[email protected] University of California, San Diego == Phone:(858) 822-2726 La Jolla, CA 92093-0230 == _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
